Re: modify ramps 1.4 to make it more reliable ? October 22, 2015 11:23PM |
Re: modify ramps 1.4 to make it more reliable ? November 04, 2015 01:54AM |
Re: modify ramps 1.4 to make it more reliable ? November 04, 2015 02:09AM |
Re: modify ramps 1.4 to make it more reliable ? November 04, 2015 02:49AM |
Re: modify ramps 1.4 to make it more reliable ? January 30, 2016 11:10PM |
Re: modify ramps 1.4 to make it more reliable ? January 31, 2016 04:17AM |
Re: modify ramps 1.4 to make it more reliable ? January 31, 2016 06:54AM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: modify ramps 1.4 to make it more reliable ? January 31, 2016 09:46AM |
Dust
That premium ramps talks a good talk but....
16volt caps under pololus, means you also cant use this ramps with 24v.
Re: modify ramps 1.4 to make it more reliable ? January 31, 2016 11:20AM |
Re: modify ramps 1.4 to make it more reliable ? January 31, 2016 09:23PM |
dc42
Dust
Also it doesn't have a 5V regulator on board to avoid relying on the often-overloaded one on the Arduino Mega. That and the 16V limitation make it a fail IMO.
Re: modify ramps 1.4 to make it more reliable ? February 01, 2016 03:20AM |
Re: modify ramps 1.4 to make it more reliable ? February 01, 2016 11:10AM |
dc42
I am not aware of any RAMPS boards that have voltage regulators on board.
I suspect that when RAMPS was first designed several years ago, nobody used GLCDs or servos on their 3D printers, and everyone made small printers that only needed 12V supplies. Also the 32-bit processors cost more than the 8-bit ones did. In that context, the RAMPS design made sense.
Re: modify ramps 1.4 to make it more reliable ? February 01, 2016 01:40PM |
Re: modify ramps 1.4 to make it more reliable ? February 01, 2016 04:02PM |
tjnamtiw
dc42
Then that board in question isn't a "fail" because it doesn't have a regulator, is it? I wish they did but ...............
