Re: first connection of my RAMPS V1.4 November 03, 2015 02:57AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: first connection of my RAMPS V1.4 November 03, 2015 08:15AM |
Re: first connection of my RAMPS V1.4 November 03, 2015 08:53AM |
Re: first connection of my RAMPS V1.4 November 03, 2015 10:20AM |
jepigepas
I have measured 1.6 ohms on mine.
I have seen on the bed resistor from where came the slam. A bubble under the coating has exploded !
I think that my resistor has some short cut.
The problem is that I have no other resistor by me...
Re: first connection of my RAMPS V1.4 November 03, 2015 10:45AM |
Re: first connection of my RAMPS V1.4 November 03, 2015 11:10AM |
jepigepas
I have no LED on my bed resistance
I am manufacturing a resistance with pencil leads.
I'll put it in series with the bed restance in order to have an overall resistance of 2.5 Ohms.
Re: first connection of my RAMPS V1.4 November 03, 2015 12:36PM |
Yes but I have a lack of time.Quote
bigfilsing
jepigepas
I have no idea how that will work. If your heated bed is indeed defect then i think you may just have to buy a new one.
Re: first connection of my RAMPS V1.4 November 03, 2015 08:39PM |
Re: first connection of my RAMPS V1.4 November 04, 2015 01:13AM |
Re: first connection of my RAMPS V1.4 November 04, 2015 02:25AM |
bigfilsing
I think you may just have to accept that your heated bed is defect and source a new one before you damage the ramps board.
You can still print PLA without a heated bed ( using painters blue tape) so you could still experiment with your printer while you wait for a new heated bed!
Its normal for the thyristors to get warm/ hot, especially the one driving the heated bed but not hot enough to melt wire insulation.
I am concerned that you will do some irreparable damage to your ramps board.
Re: first connection of my RAMPS V1.4 November 04, 2015 02:56AM |
jepigepas
bigfilsing
Could you please precise what you mean (using painters bleu tape)?
Do you advise me to paint the glass of the heated bed?
Or do you mean of an adhesive tape which has to be glued on the bed?
Re: first connection of my RAMPS V1.4 November 04, 2015 05:59PM |
Re: first connection of my RAMPS V1.4 November 07, 2015 09:32PM |
Re: first connection of my RAMPS V1.4 November 08, 2015 01:20AM |
jepigepas
Hello all of you,
I must thank you very much for your help !
Thank you Dust,
Thank you Bigfilsing,
Thank you Cozmicray,
Thanks to you I was finally able to print my first pieces using PLA.
My bed heating is out of order, so I have used blue painter's tape that I have put on a removable plastic sheet. So it is very easy to pick up the piece after printing.
I just wonder if it possible to print with ABS without bed heating ?
thanks again and best regards,
Jack
Re: first connection of my RAMPS V1.4 November 08, 2015 07:24AM |
bigfilsing
jepigepas
Hello all of you,
Thank you Dust,
Jack
You are welcome. Thanks for taking time out to say thanks. Many dont and i always appreciate it when people do.
ABS can be very tricky to get to stick . Thats why most slicer software has options to use a brim and/or a raft.
ABS can warp when printing so i dont think you can print without a heated bed im afraid.
E3D sells some filament called Polymax that prints like PLA but has similar properties to ABS but even that needs a heated bed.
SO i guess the easiest and best way forward is to be patient and order a replacement heated bed and save yourself a lot of wasted filament and frustration.
6 dollars on ebay ebay heated bed
or
7 dollars on banggood banggood heated bed ( Faster shipping)
Good luck
Re: first connection of my RAMPS V1.4 November 08, 2015 07:38AM |
Re: first connection of my RAMPS V1.4 November 08, 2015 10:52PM |
Re: first connection of my RAMPS V1.4 November 09, 2015 01:52AM |
Re: first connection of my RAMPS V1.4 November 09, 2015 04:20AM |
Re: first connection of my RAMPS V1.4 November 09, 2015 05:21AM |
jepigepas
Dear Bigfilsing,
I understand what you mean.
the diameter of hotend's nozzle is 0.4 mm
and
the filament I use is PLA
On the Arduino, I have let the predefined settings.
I have just enter heat settings in Slic3 following the wizard of the "electronic guide".
These settings are :
layer height 0.3 mm
first layer height 0.35
Speed :
perimeters 50 mm/s
small perimeters 50 mm/s or %
external perimeters 60%
Infill 50 mm/s
solid infill: 60 mm/s or %
top solid infill 50 mm/s or %
support material 60 mm/s
bridges 30 mm/s
gap fill 20 mm/s
travel 130 mm/s
first layer speed 30 mm/s or %
max print speed 80 mm/s
Filament:
diameter: 1.75 mm
extrusion multiplier: 1
Temperature: first layer 200°C ; other layers 200 °C
Bed: 0
printer settings:
Z Offset 0 mm
custom G-code:
G28; home all axes
G1 Z5 F5000; lift nozzle
End G-code:
G28 X0; home X axis
extruder:
nozzle diameter 0.4 mm
extruder offset (x: 0 ; y: 0 )
retraction:
length 0.7 mm
lift z 0
speed 15 mm/S
extra length on restart: 0
minimum travel after retraction 1 mm
That is all I see in the Slic3r.
Do you think I have any thing to change in the configuration.h ?
Re: first connection of my RAMPS V1.4 November 09, 2015 05:33AM |
jepigepas
jepigepas
Dear Bigfilsing,
and
layer height 0.3 mm
Speed :
perimeters 50 mm/s
Infill 50 mm/s
bridges 30 mm/s
gap fill 20 mm/s
travel 130 mm/s
Filament:
diameter: 1.75 mm
Bed: 0
printer settings:
Z Offset 0 mm
custom G-code:
G28; home all axes
End G-code:
G28 X0; home X axis
extruder:
retraction:
length 0.7 mm
lift z 0
speed 15 mm/S
For the diameter of the nozzle, I must add that the 0.4 mm is the diameter of the wire coming out of the nozzle.
Re: first connection of my RAMPS V1.4 November 09, 2015 06:26AM |
Re: first connection of my RAMPS V1.4 November 09, 2015 03:22PM |
Re: first connection of my RAMPS V1.4 November 09, 2015 03:27PM |
Re: first connection of my RAMPS V1.4 November 09, 2015 03:49PM |
Re: first connection of my RAMPS V1.4 November 09, 2015 10:26PM |
Re: first connection of my RAMPS V1.4 November 09, 2015 11:14PM |
Re: first connection of my RAMPS V1.4 November 10, 2015 06:24AM |
Re: first connection of my RAMPS V1.4 November 10, 2015 11:43AM |
Re: first connection of my RAMPS V1.4 November 11, 2015 12:11AM |
cozmicray
quote Bigfilsing "It looks like there is some kind of cover shroud at the hot end
to stop the air from the fan hitting the heater block . Not very efficient at all."
Confusing Statement
Cooling heater block (melting filament) is not helping
just requiring more power to keep it at temperature
Yes -- cool above heater to keep filament solid so it can feed
Yes -- cool after extrusion to solidify part.
Black shroud is probably silicone insulator
more for prevention of burning flesh.
