Re: Due + RADDS @ DIY core XY und nur Ärger 07. June 2017 03:20 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 155 |
Re: Due + RADDS @ DIY core XY und nur Ärger 07. June 2017 05:25 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
#define HOMING_FEEDRATE_Z 20 //changed
#define MIN_HARDWARE_ENDSTOP_X true //changed #define MIN_HARDWARE_ENDSTOP_Y true //changed #define MIN_HARDWARE_ENDSTOP_Z true //changed #define MAX_HARDWARE_ENDSTOP_X true //changed #define MAX_HARDWARE_ENDSTOP_Y true //changed #define MAX_HARDWARE_ENDSTOP_Z true //changedFeedrate hattest Du vorher auf 2. Setz die mal auf 5.
Re: Due + RADDS @ DIY core XY und nur Ärger 09. June 2017 17:01 |
Re: Due + RADDS @ DIY core XY und nur Ärger 18. June 2017 19:36 |
Re: Due + RADDS @ DIY core XY und nur Ärger 19. June 2017 04:48 |
#define EXT0_MAX_START_FEEDRATE 40
#define EXT0_EXTRUDER_COOLER_PIN -2 //changed, before: -1
Start-Feedrate zu hoch. -1 steht für "nicht vorhanden", hier die Pin-Nr. eintragen.
Re: Due + RADDS @ DIY core XY und nur Ärger 19. June 2017 09:20 |
Re: Due + RADDS @ DIY core XY und nur Ärger 15. October 2017 17:46 |
Re: Due + RADDS @ DIY core XY und nur Ärger 08. April 2018 15:14 |
// ############# Heated bed configuration ######################## /** \brief Set true if you have a heated bed conected to your board, false if not */ #define HAVE_HEATED_BED true #define HEATED_BED_MAX_TEMP 120 /** Skip M190 wait, if heated bed is already within x degrees. Fixed numbers only, 0 = off. */ #define SKIP_M190_IF_WITHIN 5 // Select type of your heated bed. It's the same as for EXT0_TEMPSENSOR_TYPE // set to 0 if you don't have a heated bed #define HEATED_BED_SENSOR_TYPE 1 /** Analog pin of analog sensor to read temperature of heated bed. */ #define HEATED_BED_SENSOR_PIN TEMP_4_PIN /** \brief Pin to enable heater for bed. */ #define HEATED_BED_HEATER_PIN HEATER_1_PIN // How often the temperature of the heated bed is set (msec) #define HEATED_BED_SET_INTERVAL 5000
