Any info on Kisslicer? March 12, 2014 08:19PM |
Re: Any info on Kisslicer? March 12, 2014 08:41PM |
Jomo
Jomo
Re: Kisslicer
03/12/2014 05:02PM
I just started using Kisslicer and I think that I am getting better results then Slic3r.
I had a few issues and questions I hope some one can answer.
I have the first layer temp set higher then the rest but when the layer finishes, the nozzle just sits there for a little bit while the temp drops. This caused some damage to the part. Any way to lift the nozzle?
I would like to set a minimum time per layer. I thought I read that it has that control but cant find it
My printer shakes a lot when infilling the corners. Is there a control to slow that down?
I am surprised that there are so few messages here is there another forum that talks about Kisslicer?
Thanks folks and I got some good ideas already from what is posted here now.
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Any info on Kisslicer? March 12, 2014 08:52PM |
Re: Any info on Kisslicer? March 13, 2014 01:11PM |
Sublime
... but it could be you need to change your firmware acceleration and jerk settings.
Re: Any info on Kisslicer? March 13, 2014 08:30PM |
