Hi Andreas,
why does it start skipping at a higher level? Do you extrude to much? Does the nozzle start to scratch across the part?
If not:
check if the extruder gear is centered to the filament,
tighten the filament feed spring,
reduce print speed,
raise extruder current.
Only do one change at a time.
