May the Foam be with you. June 19, 2016 12:54PM |
Re: May the Foam be with you. June 19, 2016 01:03PM |
Re: May the Foam be with you. June 19, 2016 01:34PM |
Re: May the Foam be with you. June 19, 2016 01:43PM |
the_digital_dentist
With a title like that I was expecting to see a life size Yoda head...
I think with tall, small footprint parts like the tower or tube you printed, the foam may sag under the print's weight and it may tilt. Tall, small footprint parts are a problem for any printer...
Re: May the Foam be with you. June 19, 2016 01:45PM |
it is not smooth like when printed on glass, but the foam comes off easily. i would use a deburring tool.Quote
deaconfrost
thats actually good for large scale printer like 400mmx400mm plus size, save energy and the headache on working out the heatbed
how is the bottom surface of the finish and how well the foam comes off?
Re: May the Foam be with you. June 19, 2016 03:36PM |
Re: May the Foam be with you. June 20, 2016 03:58AM |
Re: May the Foam be with you. June 20, 2016 09:02AM |
Re: May the Foam be with you. June 22, 2016 01:15AM |
Re: May the Foam be with you. June 22, 2016 03:39PM |
Re: May the Foam be with you. June 23, 2016 05:41PM |
Re: May the Foam be with you. June 23, 2016 07:20PM |
MechaBits
Why Use Foam, Why use more than one layer of tape(because I have tape not foam), because I'm a beginner after good adhesion(no heatbed), 1 layer was ok, but I added a few more to give me a little wiggle room, without eh cusioning I might not get anything coming out the nozzle, I have not yet mastered the correct way to start things off with the required Z heights offset code, homing, as I have no end stops or sensors working yet, 0.2 could be too high, 0.1 might be better for me, so I just bring head low to the tape and start the print, if it was too low I would have nothing coming out, sometimes it is a little thin, so I can make a few parts to add to the machine, as time goes by i'll get round to doing other things to improve the start procedure. Better Bed(Mic6), I'm still using acrylic to support the heat plate one of the first parts I had made which will be retired when I get some access to better tools.
I dont have layer width settings and have read conflicting info on first layer height, if I do .28 for layers, I tried .32 for first layer, but also read it should be lower, I have links to both trains of thought, one comes from hints in Matter Control "it is often desirable to print a taller first layer for good adhesion" but in another guide it says the opposite.
but it is an early days experiment, and the current tape is not sticky enough for all parts, and can still lift, its not even blue but normal masking tape. Maybe it's because of the cushioning...
I'm not averse to trying some foam as long as it has a very fine structure, like that flower arranging stuff, but that might be just a little too crumbly.
deaconfrost
check this out
ABS no heat bed
I broke it trying to take it off, but I didn't actually give it time after print was finished and its hollow with only 0.8mm bottom which wouldn't help either
Re: May the Foam be with you. June 23, 2016 07:54PM |
Re: May the Foam be with you. June 24, 2016 03:43PM |
Re: May the Foam be with you. June 24, 2016 04:02PM |
Re: May the Foam be with you. June 24, 2016 04:45PM |
Re: May the Foam be with you. June 24, 2016 07:16PM |
Re: May the Foam be with you. June 24, 2016 07:34PM |
Re: May the Foam be with you. June 24, 2016 07:56PM |
Re: May the Foam be with you. June 24, 2016 08:14PM |
Re: May the Foam be with you. June 24, 2016 08:34PM |
Re: May the Foam be with you. June 24, 2016 11:08PM |
Re: May the Foam be with you. June 25, 2016 01:57AM |
Re: May the Foam be with you. July 11, 2016 12:01PM |
deaconfrost
check this out
ABS no heat bed
Re: May the Foam be with you. July 11, 2016 12:27PM |
Re: May the Foam be with you. July 11, 2016 12:41PM |
MechaBits
No, I get they are not the same I dont remember saying they where, (i did manage to get the layers very flat and wanted to protect underneath surface/ if I went too low)
I get it doesn't need leveling, I get the fact you bury your print in it and your first layer is level, I just tried burying it in my masking tape,
it works, though perhaps not as good as foam, how much is this stuff?(the pictures above make the sheet/printer look big)
I dont yet get how you print parts that remove from a raft with a nice finnish, or how to not have the part warp at the air gap
and remove itself from the raft...not got that far but foam is on the list of things to try at some point when I figure which of my parts its suited to.
Re: May the Foam be with you. July 11, 2016 12:44PM |
the_digital_dentist
Yes, you peel the foil/paper off. Peeling it won't do enough damage to the surface to affect your prints. If the surface does get damaged deeply for any reason, just sand it sort of smooth with coarse sandpaper and print on it.
Yes, you still need a warm enclosure to print ABS without delaminating.
I haven't tried flexible filament on it, but it's a good idea. I have some TPU filament- I'll try this weekend. I'd bet that it works fine, but there's no beating a test to know for sure.
Re: May the Foam be with you. July 11, 2016 08:23PM |
val c.
deaconfrost
check this out
ABS no heat bed
what kind of plastic is that?
Re: May the Foam be with you. July 12, 2016 11:38AM |
deaconfrost
val c.
deaconfrost
check this out
ABS no heat bed
I'm not sure I couldn't get an answer as I need a 500mm x 500mm and the shop looking for stupid money for it, 180 euro for 400mm x 400mm, heres where I got it
build plate
I'll be using plastic primer on the large printer and in the mean time I will send the plate off to find out what it is.
here's another print of abs 60% infill
ABS no heat bed
I also tested PETG which works really well. the PLA print quality are super on this plate
Re: May the Foam be with you. July 12, 2016 02:18PM |
