Hello everyone
I built a printer similar to Prusa.
Manually moving the individual axes makes them no problem at all.
Apro Repetier-Host, I make settings for my printer and save everything.
Load the 20x20 mm cube to perform the print test, click on start printing, and what the printer does .....?
Holds in the Home heat heater expander then arrives at temperature moves and goes to position
In the opposite corner of Home and starts extruding them only on Z axis.
It does not move on X and Y axis, but it stays and moves only in height ie Z.
I think it's a Marlin configuration problem, but I do not know what lines to set.
I hope in your help.
Thank you
Greetings from Paul
