Print not sticking to bed... bluetape December 19, 2017 10:48AM |
; generated by Slic3r 1.2.9 on 2017-12-19 at 10:31:27 ; external perimeters extrusion width = 0.40mm ; perimeters extrusion width = 0.48mm ; infill extrusion width = 0.48mm ; solid infill extrusion width = 0.48mm ; top infill extrusion width = 0.48mm M107 M104 S195 ; set temperature ;G28 ; home all axes G1 Z5 F500 ; lift nozzle M109 S195 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 G1 Z0.300 F7800.000 G1 E-2.00000 F2400.00000 G92 E0 G1 X121.523 Y121.522 F7800.000 G1 E2.00000 F2400.00000 G1 X123.046 Y120.071 E2.08151 F1800.000 G1 X124.761 Y118.592 E2.16925 G1 X126.546 Y117.207 E2.25676 G1 X128.392 Y115.921 E2.34394 G1 X130.292 Y114.737 E2.43066 G1 X132.237 Y113.659 E2.51681 G1 X134.218 Y112.688 E2.60231 G1 X136.519 Y111.710 E2.69917 ...
Re: Print not sticking to bed... bluetape December 19, 2017 10:54AM |
Re: Print not sticking to bed... bluetape December 19, 2017 01:42PM |
Re: Print not sticking to bed... bluetape December 19, 2017 02:02PM |
Re: Print not sticking to bed... bluetape December 19, 2017 03:59PM |
Re: Print not sticking to bed... bluetape December 19, 2017 06:01PM |
ampapa
HD version , I can't really get a piece of paper between it and the print bed.
Re: Print not sticking to bed... bluetape December 20, 2017 08:02AM |
Re: Print not sticking to bed... bluetape December 20, 2017 09:08AM |
Re: Print not sticking to bed... bluetape December 20, 2017 10:35AM |
Digital Dentist
Does the extruder click as it is trying to print that first layer?
McCarman
Also worth increasing the 1st layer extrusion multiplier to 150% to generate pressure and even out errors.
Re: Print not sticking to bed... bluetape December 20, 2017 12:28PM |
Re: Print not sticking to bed... bluetape December 20, 2017 12:44PM |
Re: Print not sticking to bed... bluetape December 20, 2017 01:56PM |
checking that as I type... if its on 3mmm it's definitely wrong.Quote
obiwan
the bottom picture shows a filament diameter of 3 mm, is this what you are using ? most fillaments are 1.75mm. these days.
Re: Print not sticking to bed... bluetape December 20, 2017 02:39PM |
Re: Print not sticking to bed... bluetape December 20, 2017 03:05PM |
Re: Print not sticking to bed... bluetape December 20, 2017 05:17PM |
Re: Print not sticking to bed... bluetape December 20, 2017 09:03PM |
Re: Print not sticking to bed... bluetape December 20, 2017 09:52PM |
Re: Print not sticking to bed... bluetape December 20, 2017 09:57PM |
Re: Print not sticking to bed... bluetape December 21, 2017 08:47AM |
Re: Print not sticking to bed... bluetape December 21, 2017 08:12PM |
obewan
From the video, i see no filament being extruded during the print, this could be the above menssioned setting or nozzle being too close to the bed,restricting the flow.
Also i would set the 1st layer temperature a bit higher(210-220) to help 1st layer bed adhesion.
Print speed settings are set in the 1st picture,under speed, might be a tad fast atm.
Re: Print not sticking to bed... bluetape December 22, 2017 02:48AM |
Re: Print not sticking to bed... bluetape December 23, 2017 11:23AM |
Re: Print not sticking to bed... bluetape December 24, 2017 03:58AM |
Re: Print not sticking to bed... bluetape December 24, 2017 07:48AM |
Re: Print not sticking to bed... bluetape December 26, 2017 12:37PM |
Re: Print not sticking to bed... bluetape December 26, 2017 06:08PM |
Re: Print not sticking to bed... bluetape December 26, 2017 06:45PM |
Re: Print not sticking to bed... bluetape December 26, 2017 06:58PM |
Re: Print not sticking to bed... bluetape December 26, 2017 07:45PM |
Re: Print not sticking to bed... bluetape December 26, 2017 08:31PM |
