Possible bug in slic3r? November 29, 2018 04:13PM |
Re: Possible bug in slic3r? November 29, 2018 05:08PM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Possible bug in slic3r? November 29, 2018 05:13PM |
Re: Possible bug in slic3r? November 29, 2018 05:27PM |
Re: Possible bug in slic3r? November 29, 2018 05:37PM |
Re: Possible bug in slic3r? November 29, 2018 06:12PM |
Re: Possible bug in slic3r? November 29, 2018 09:04PM |
Re: Possible bug in slic3r? December 02, 2018 02:59PM |
Re: Possible bug in slic3r? December 02, 2018 05:07PM |
Re: Possible bug in slic3r? December 02, 2018 06:33PM |
Re: Possible bug in slic3r? December 03, 2018 04:00AM |
Re: Possible bug in slic3r? December 03, 2018 04:27AM |
MKSA
Gee, so many infill choices, parameters ... so I used to select honeycomb. Now I discover most are useless gimmicks.
Re: Possible bug in slic3r? December 03, 2018 04:42AM |
Re: Possible bug in slic3r? December 03, 2018 04:44AM |
Re: Possible bug in slic3r? December 03, 2018 06:18AM |
Re: Possible bug in slic3r? December 03, 2018 07:21AM |
Re: Possible bug in slic3r? December 03, 2018 07:24AM |
the_digital_dentist
Infill can be thicker than outer perimeters if you use Slic3r. For example, slice in 100 um layers and in the infill section, under "Reduce printing time" select "combine infill every" and set it to 3 layers. You'll get 100 um perimeters and 300 um infill (assuming you have an appropriate sized nozzle in the extruder). Cura can probably do this, too.
