"Randon" fat lines on outside, can't find any example on the issue March 01, 2021 08:59AM |
Re: "Randon" fat lines on outside, can't find any example on the issue March 01, 2021 12:07PM |
Re: "Randon" fat lines on outside, can't find any example on the issue March 01, 2021 01:41PM |
blkzera
i have a corexy homemade printer and i am with the same issue. I think it called ghosting issue, you should look into it, i may be wrong, but do a google to see if you think it is similar.
Re: "Randon" fat lines on outside, can't find any example on the issue March 02, 2021 03:24AM |
Re: "Randon" fat lines on outside, can't find any example on the issue March 02, 2021 07:15AM |
Re: "Randon" fat lines on outside, can't find any example on the issue March 02, 2021 08:50AM |
Re: "Randon" fat lines on outside, can't find any example on the issue March 02, 2021 12:17PM |
Re: "Randon" fat lines on outside, can't find any example on the issue March 02, 2021 02:12PM |
Re: "Randon" fat lines on outside, can't find any example on the issue March 02, 2021 02:59PM |
Re: "Randon" fat lines on outside, can't find any example on the issue March 12, 2021 09:29AM |
Re: "Randon" fat lines on outside, can't find any example on the issue May 03, 2021 11:52AM |
Re: "Randon" fat lines on outside, can't find any example on the issue May 03, 2021 01:05PM |
Re: "Randon" fat lines on outside, can't find any example on the issue May 04, 2021 02:56AM |
Re: "Randon" fat lines on outside, can't find any example on the issue May 04, 2021 08:50AM |
drmaestro
I think it might be a problem related to the extrusion of the plastic or cooling maybe and I feel like it is a physics problem and not something that can be corrected.
Re: "Randon" fat lines on outside, can't find any example on the issue May 04, 2021 11:13AM |
Re: "Randon" fat lines on outside, can't find any example on the issue May 04, 2021 01:10PM |
drmaestro
It is true that fluctuations in bed temperature would create expensions or shrinkages, however I am quite sure that my problem is different. My reasons:
Re: "Randon" fat lines on outside, can't find any example on the issue (solved) May 26, 2021 02:02PM |
