Slicing Objects
June 03, 2013 10:33AM
I am trying to slice a few floor plans. Like this one here: [www.thingiverse.com]
I have printed it out using Skeinforge many times. at 100micron and 200micron. When I slice it in slic3r all i get is a solid block. This happends with other objects with lots of detail. I am using the 0.9.9 release.
Here are my settings:
# generated by Slic3r 0.9.9-dev on Mon Jun 3 07:27:12 2013
avoid_crossing_perimeters = 1
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_flow_ratio = 1
bridge_speed = 60
brim_width = 0
complete_objects = 0
default_acceleration = 0
external_perimeter_speed = 70%
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extrusion_width = .35
fill_angle = 45
fill_density = 0.50
fill_pattern = rectilinear
first_layer_extrusion_width = 200%
first_layer_height = 0.30
first_layer_speed = 50%
gap_fill_speed = 20
gcode_comments = 0
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_speed = 60
layer_height = 0.3
min_skirt_length = 0
notes =
only_retract_when_crossing_perimeters = 1
output_filename_format = [input_filename_base].gcode
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 30
perimeters = 1
post_process =
raft_layers = 0
randomize_start = 1
resolution = 0
skirt_distance = 6
skirt_height = 1
skirts = 2
small_perimeter_speed = 30
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0
solid_infill_speed = 60
support_material =
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 2
support_material_extrusion_width = 0
support_material_interface_layers = 0
support_material_interface_spacing = 0
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 60
support_material_threshold = 0
threads = 2
top_infill_extrusion_width = 0
top_solid_infill_speed = 50
top_solid_layers = 3
travel_speed = 130
Thanks
Jeff
Edited 1 time(s). Last edit at 06/03/2013 10:34AM by Adventure.
Jeff Christiana
