slic3r not running in Linux Mint 'Mate' with nouveau driver September 12, 2020 07:56AM |
./Slic3r-1.3.0-x86_64.AppImage
libGL error: MESA-LOADER: failed to open nouveau (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
libGL error: failed to load driver: nouveau
libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
libGL error: failed to load driver: swrast
The program 'slic3r.pl' received an X Window System error.
This probably reflects a bug in the program.
The error was 'GLXBadContext'.
(Details: serial 1189 error_code 158 request_code 152 minor_code 6)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
