REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 22, 2014 07:00PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 22, 2014 10:02PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 05:37AM |
Pointless
juga con el pote
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 06:50AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 06:53AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 06:56AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 07:02AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 08:13AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 08:22AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 08:23AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 08:25AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 08:33AM |
tatubias
Por si la s mil. La libros la tenés instalada?
Marlin V1 (new)
Installation: In "Configuration.h”
Change “#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER” (just remove the // at the beginning)
==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com]
Upload the firmware, power off the Arduino, connect the panel, reapply power, and everything should work.
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 08:39AM |
Lechonquinto
El trim es el pote.
Creo que es para el contraste o algo así, de pantalla lcd no tengo idea.
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 08:47AM |
tatubias
Pregunta paba.
Te asegúrate que los cables estén conectados en el sentido correcto?
Y el pote no es el d la derecha. Sino el de la izquierda con punta de destornilador phillips. El blanco. Con base azul
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 09:02AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 03:50PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 04:10PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 23, 2014 05:21PM |
tatubias
Escribite un tutorial de como lo solucionaste!!! asi me ahorro 57683089762350692357 renegando con la pantalla cuando me la traiga papa noel
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 24, 2014 04:21PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 24, 2014 07:17PM |
jameghino
@AleCun, nuevamente voy con el mismo mensaje. Hay que ser mas generoso con la comunidad. A este foro viniste por ayuda, a este foro dedicale 10 minutos para escribir la solución detallada con toda la información (detalle por detalle) que fue lo que te puso tu amigo, links, etc. No seas fiaca,che.
Sino, muchachas y muchachos, asi no sirve. Y realmente creo que debe ser así con todo, digo, te lo resolvieron, compartilo 100% y con ganas.
Quedo atento a ver si pones mas voluntad.
Saludos
Javier
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 25, 2014 06:11AM |
AleCun
@jameghino!... Soy generoso y agradecido a la comunidad... A propósito pregunto: ¿por que me estas prejuzgando?...A este foro vine porque me dijeron que hay gente muy copada como vos y miles mas, y quien me ha dicho eso ¡¡¡no estaba equivocado!!!... me comprometí con @Dani (integrate de esta comunidad, quien me dio una mano muy valiosa) a hacer el tutorial.. """Y lo voy a hacer""""... Solo dame mas de 10 minutos, ya que estoy hasta las "bolas con los tiempos"... (laburo todo los días hasta el 1º de enero inclusive) A PROPÓSITO!... FELICES FIESTAS A TODA LA BANDAAAAA!... GROSOOOOSSSS!...
Queres un informe pedorro?... te lo escribo YA!.. querés una solución mas detallado?... Dame tiempo a que lo pueda analizar!...
Saludos y Feliz Navidad!...
Alejandro
PD:A ponerse en pedo genteeee!..... ya que yo me voy a dormir porque me levanto a las 05:00Hs, FELIZ NAVIDAD PARA TODOS!!!!!
jameghino
Saludos
Javier
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 25, 2014 09:37AM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 25, 2014 04:11PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 25, 2014 04:48PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 25, 2014 05:11PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 25, 2014 05:56PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 25, 2014 06:35PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 25, 2014 10:09PM |
Re: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER no funciona December 25, 2014 11:43PM |
danale17
buenas noches gente! vengo leyendo hace rato y en este caso a consultar porque tengo un problema similar, tengo un lcd de 4x20 lineas creo le llaman asi, de los que se ven en los tutoriales pero en su defecto de placa roja.
no logro hacerlo andar, he leido que para la pantalla de este post, se necesitan las librerias, yo hasta con eso probe, pero no logro que ande, lo maximo que hace es mostrar simbolos raros.
firmware? de todos los tutos que vi, editados, sin editar, y en si editados ya que algunos venian con las barras comentados y como indica, para activar solo habia que borrar dos barras del que describe como placa en blanco (siendo que la mia es roja) y borrando las dos barras de la opcion de soporte de tarjeta SD
#define SDSUPPORT // Enable SD Card Support in Hardware Console
// The RepRapDiscount Smart Controller (white PC
// [reprap.org]
#define REPRAP_DISCOUNT_SMART_CONTROLLER
por lo que vi, no necesita librerias, ya he probado de todo y no logro que ande.
hay un video en zonamaker que el muchacho la presenta pero usa la full graphic.. diciendo justamente esto y en otros videos he visto lo mismo pero no anda.
el arduino es el 1.0.6 y el marlin ya ni idea que le quedo cargado, porque hoy se lo acabo de cargar 12 veces.
les dejo 2 fotos a ver si me iluminan.
por el momento estoy de viaje y mi impresora viajando semi armada a 800kms.. la idea era llegar con el lcd andando.. he probado un motor y funciona bien, pero me quede sin tiempo por laburo, ahora ya mas tranqui y de vacaciones me puse, pero no doy pie con bola.
espero alguien la tenga y me diga que estoy haciendo mal.
exitos!
Danale
