New E3D-V6 hotend - with10% off..... May 25, 2014 01:15PM |
Re: New E3D-V6 hotend - with10% off..... May 26, 2014 07:43PM |
Re: New E3D-V6 hotend - with10% off..... May 27, 2014 09:16AM |
Re: New E3D-V6 hotend - with10% off..... May 27, 2014 09:49AM |
Re: New E3D-V6 hotend - with10% off..... May 27, 2014 11:39AM |
Re: New E3D-V6 hotend - with10% off..... May 27, 2014 07:37PM |
Re: New E3D-V6 hotend - with10% off..... May 29, 2014 07:50AM |
Re: New E3D-V6 hotend - with10% off..... May 29, 2014 03:58PM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 04:32AM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 05:04AM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 08:09AM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 09:21AM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 09:33AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 11:03AM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 02:03PM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 03:54PM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 08:26PM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 08:33PM |
Re: New E3D-V6 hotend - with10% off..... May 30, 2014 08:58PM |
Re: New E3D-V6 hotend - with10% off..... May 31, 2014 08:15AM |
Re: New E3D-V6 hotend - with10% off..... May 31, 2014 09:01AM |
Re: New E3D-V6 hotend - with10% off..... May 31, 2014 09:29AM |
Re: New E3D-V6 hotend - with10% off..... May 31, 2014 10:06AM |
nophead
I wouldn't say 245C was right at the end of what a J-Head can do. I print all the parts of the kit at 250C and on some of my machines I do the first layer at 255C. I wouldn't go higher than that though.
Re: New E3D-V6 hotend - with10% off..... May 31, 2014 12:29PM |
I have 2 40mm M3 bolts from the side going through the extruder holding in my E3D now and that seems to hold it firmly. It goes 12mm into the block. The 3 mounting screws work abysmally with the E3D as the heatsink is wide so I really couldn't see another way to go for a firm mounting.Quote
nophead
The actually length of a J-head Mk5 is 51.2mm, although the Mendel90 was designed assuming it was 54mm. So 8.3mm would need to go into the Wades.
That is doable I think but not with the three screw mounting I use. I have tried various clamping from the side schemes before but they didn't hold it firm enough, so it waggled. That means going back to two screws all the way through the extruder, which I never liked.
Re: New E3D-V6 hotend - with10% off..... May 31, 2014 02:57PM |
Re: New E3D-V6 hotend - with10% off..... May 31, 2014 04:06PM |
Re: New E3D-V6 hotend - with10% off..... May 31, 2014 05:28PM |
Re: New E3D-V6 hotend - with10% off..... June 01, 2014 07:15AM |
Re: New E3D-V6 hotend - with10% off..... June 01, 2014 12:05PM |
Re: New E3D-V6 hotend - with10% off..... June 01, 2014 12:08PM |
