Re: [problemy] - kalibrace May 09, 2015 11:00AM |
Re: [problemy] - kalibrace May 10, 2015 02:49AM |
Re: [problemy] - kalibrace May 10, 2015 06:28AM |
Re: [problemy] - kalibrace May 10, 2015 08:12AM |
Re: [problemy] - kalibrace May 10, 2015 08:25AM |
Re: [problemy] - kalibrace May 10, 2015 08:59AM |
Re: [problemy] - kalibrace May 10, 2015 09:11AM |
Re: [problemy] - kalibrace May 10, 2015 09:54AM |
Re: [problemy] - kalibrace May 10, 2015 10:15AM |
Re: [problemy] - kalibrace May 10, 2015 10:27AM |
Re: [problemy] - kalibrace May 10, 2015 10:46AM |
Re: [problemy] - kalibrace May 10, 2015 11:10AM |
Re: [problemy] - kalibrace May 10, 2015 12:08PM |
Re: [problemy] - kalibrace May 11, 2015 05:38AM |
Re: [problemy] - kalibrace November 04, 2015 01:34PM |
Re: [problemy] - kalibrace November 22, 2015 12:33PM |
Re: [problemy] - kalibrace November 22, 2015 03:26PM |
Re: [problemy] - kalibrace November 22, 2015 05:16PM |
Re: [problemy] - kalibrace November 22, 2015 06:51PM |
Re: [problemy] - kalibrace November 22, 2015 06:53PM |
Re: [problemy] - kalibrace November 23, 2015 11:58AM |
lubosjerabek
Tam ti něco prokluzuje, nebo drhne: buď prokluzuje motor protože má málo proudu, nebo nějaký problém v mechanice, bez elektriky to rukou jde vpohodě ?
koncak by to nemal byt. keby sa to suplo na x=0 tak by to posunulo nie o milimeter-dva ale o dost a do plusu. mne to ide do minusu. koncaky mam tieto, maju dost silnu strunu vnutri. nemyslim ze by to kmitalo.Quote
lubosjerabek
případně ještě koncák, jak se to celé klepe, tak může občas rozepnout, tím by se to šouplo na X=0 (mě jednou blbnul kabel ke koncáku a bylo to podobný)
Re: [problemy] - kalibrace November 23, 2015 03:16PM |
Re: [problemy] - kalibrace November 26, 2015 03:14PM |
Re: [problemy] - kalibrace November 27, 2015 04:48AM |
Re: [problemy] - kalibrace November 27, 2015 12:46PM |
Re: [problemy] - kalibrace November 27, 2015 01:04PM |
Re: [problemy] - kalibrace December 25, 2015 05:28AM |
Re: [problemy] - kalibrace December 25, 2015 12:08PM |
Re: [problemy] - kalibrace December 26, 2015 03:27AM |
Re: [problemy] - kalibrace December 26, 2015 03:43AM |
Moderator Registered: 10 years ago Posts: 1,038 |
Bezdak821
V tom problém nevidím, řemen je napnuty tak, jak by měl být a tyče se k sobě určitě nenaklonily. Kdyby mi držely ložiska, tak bude výtisk zkažený po ostatních osach, ne? Můj problém je, ze u vyšších vrstev nepohybuje tryska nad výrobkem, ale v něm. Když přejíždi na jinou pozici, tak slyším jak naráží již do ztuhleho plastu
