Re: Bautagebuch Sparkcube v1 12. April 2014 10:28 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 220 |
Re: Bautagebuch Sparkcube v1 12. April 2014 12:27 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 567 |
Re: Bautagebuch Sparkcube v1 12. April 2014 13:24 |
// ################ Endstop configuration ##################### #define ENDSTOP_PULLUP_X_MIN true #define ENDSTOP_X_MIN_INVERTING false #define MIN_HARDWARE_ENDSTOP_X true #define ENDSTOP_PULLUP_Y_MIN true #define ENDSTOP_Y_MIN_INVERTING false #define MIN_HARDWARE_ENDSTOP_Y false #define ENDSTOP_PULLUP_Z_MIN true #define ENDSTOP_Z_MIN_INVERTING false #define MIN_HARDWARE_ENDSTOP_Z true #define ENDSTOP_PULLUP_X_MAX true #define ENDSTOP_X_MAX_INVERTING false #define MAX_HARDWARE_ENDSTOP_X false #define ENDSTOP_PULLUP_Y_MAX true #define ENDSTOP_Y_MAX_INVERTING false #define MAX_HARDWARE_ENDSTOP_Y true #define ENDSTOP_PULLUP_Z_MAX true #define ENDSTOP_Z_MAX_INVERTING false #define MAX_HARDWARE_ENDSTOP_Z false #define max_software_endstop_r true #define min_software_endstop_x false #define min_software_endstop_y true #define min_software_endstop_z false #define max_software_endstop_x true #define max_software_endstop_y false #define max_software_endstop_z true #define ENDSTOP_X_BACK_MOVE 5 #define ENDSTOP_Y_BACK_MOVE 5 #define ENDSTOP_Z_BACK_MOVE 1 #define ENDSTOP_X_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_X_BACK_ON_HOME 1 #define ENDSTOP_Y_BACK_ON_HOME 1 #define ENDSTOP_Z_BACK_ON_HOME 0 #define ALWAYS_CHECK_ENDSTOPS 0
Re: Bautagebuch Sparkcube v1 12. April 2014 15:30 |
Re: Bautagebuch Sparkcube v1 12. April 2014 15:35 |
// ################# XYZ movements ################### #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define DISABLE_X 0 #define DISABLE_Y 0 #define DISABLE_Z 0 #define DISABLE_E 0 #define INVERT_X_DIR 0 #define INVERT_Y_DIR 0 #define INVERT_Z_DIR 0 #define X_HOME_DIR -1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1 #define X_MAX_LENGTH 200 #define Y_MAX_LENGTH 200 #define Z_MAX_LENGTH 200 #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0
Re: Bautagebuch Sparkcube v1 12. April 2014 15:37 |
Re: Bautagebuch Sparkcube v1 12. April 2014 16:16 |
Re: Bautagebuch Sparkcube v1 12. April 2014 16:33 |
Re: Bautagebuch Sparkcube v1 12. April 2014 16:41 |
Re: Bautagebuch Sparkcube v1 13. April 2014 03:13 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.689 |
Re: Bautagebuch Sparkcube v1 15. April 2014 07:16 |
Re: Bautagebuch Sparkcube v1 15. May 2014 06:54 |
Re: Bautagebuch Sparkcube v1 25. May 2014 10:18 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 3.385 |
Re: Bautagebuch Sparkcube v1 27. May 2014 15:12 |
Re: Bautagebuch Sparkcube v1 28. May 2014 04:46 |
Re: Bautagebuch Sparkcube v1 28. May 2014 04:58 |
Re: Bautagebuch Sparkcube v1 28. May 2014 05:06 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 57 |
Re: Bautagebuch Sparkcube v1 28. May 2014 05:15 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 42 |
Re: Bautagebuch Sparkcube v1 28. May 2014 05:57 |
Re: Bautagebuch Sparkcube v1 28. May 2014 07:09 |
Re: Bautagebuch Sparkcube v1 11. June 2014 05:14 |
Wo findet man da nähere infos?
Re: Bautagebuch Sparkcube v1 03. July 2014 12:35 |
Re: Bautagebuch Sparkcube v1 03. July 2014 18:06 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 8 |
Re: Bautagebuch Sparkcube v1 05. July 2014 07:39 |
Re: Bautagebuch Sparkcube v1 06. July 2014 09:52 |
Re: Bautagebuch Sparkcube v1 08. July 2014 17:46 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 152 |
xraceweb
Hey Leute,
Mein Drucker ist im Prinzip fertig, und druckt auch wirklich schön. Allerdings habe ich diesen Super mega tollen "SD READ ERROR" #not. Deshalb bricht jeder Druck früher oder später ab und ich kann nichts dagegen machen .. Neues Display, neues Netzteil, Displaykabel mit Aluklebeband abgeschirmt und geerdet, aber immer noch der selbe Fehler So langsam hab ich auch echt keine Lust mehr da rumzubasteln wenn eh nix funktioniert.
Falls mit jemand helfen kann oder den Drucker möchte -> PN.
lg
Re: Bautagebuch Sparkcube v1 08. July 2014 17:59 |
Re: Bautagebuch Sparkcube v1 09. July 2014 16:49 |
xraceweb
Nein, verdrillt sind die Kabel nicht, geht bei einem Flachbandkabel eher schwer, meinst du das ist die Lösung ? Ich hab bisher nur Aluminiumklebeband über die Kabel gewickelt und dann an Maße angeschlossen.
Nun, Display ist hinten am Ramps angeschlossen, mit Adapter, danach gehts gleich raus aus der Plastikbox und zum Display. Motorkabel gehen nach vorne weg und raus auf der anderen Seite der Box ..
lg
Re: Bautagebuch Sparkcube v1 09. July 2014 16:52 |
Re: Bautagebuch Sparkcube v1 09. July 2014 17:02 |
