Looking to buy 3D printer and looking at Ormerod 2 December 10, 2015 01:25PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 10, 2015 02:21PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 10, 2015 02:44PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 10, 2015 04:15PM |
1pennyshort
I was recently in the same exact position, here's a bit of my experience. I got set on the Ormerod vs. I3 pretty early on, so not much to comment on that.
In terms of the vendor, first of all, the price difference between Replikeo and Reprappro (or RS) is not quite that big. It also depends on where you are, shipping can get expensive.
I went with Replikeo. Shipping to US was about $75.
Overall, two main comments: if you don't mind fixing stuff and you are ready to tinker, then the Replikeo kit will be ok, but make sure the price difference is justified. Also, expect stuff to fail and do not expect customer service.
The kit was not quite the quality of what I see Reprappro is shipping. What I ended up getting was a hybrid: a 528.4 model with a quickset hot end.
The printed parts were a mixed bag. A month later, about half of them are already split or cracked. That may be a common problem, I don't know. It doesn't bother me much, some maintenance is expected for a kit printer. The belts were thicker, the pulleys were different (20 teeth vs the usual 18), the heater cartridge died after a few seconds. The wire looms are not shielded and with a crappy heatshrink. I had to redo and fix some of the crimping, those failures are a major pain to track down. So far, crimping was bad to the heater cartridge and to the bed thermistor.
Replikeo Support is virtually non-existant, so expect to buy any replacement parts yourself from a different source. On the positive side, I sure as hell learned a lot more through debugging a less than perfect kit than I would have otherwise.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 10, 2015 04:26PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 10, 2015 04:42PM |
Darathy
DC42 also makes touchscreen controller but you will have to buy the touchscreen: [miscsolutions.wordpress.com]
Well i think the electronics should be fine ,just get a pully with 18teeth(can wait till u get it and see if you get it with Replikeo) and mybe a thiner MXL belt so it will fit into the slots easyer.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 10, 2015 05:37PM |
Yes, the electronics are pretty standard, ethernet, SD card slot, micro-usb. The Duet case on the other hand is pretty crappy.Quote
brlowe
The touchscreen setup I was looking at is the one that DC42 came up with.
1pennyshort did the printer from replikeo come with and sdcard slot? I want to be able to print without a computer if needed some times.
Darathy
Re: Looking to buy 3D printer and looking at Ormerod 2 December 10, 2015 05:48PM |
Interesting. RS components has it for £351 (whatever that is in $) plus shipping, which is a lot closer to the Replikeo price.Quote
brlowe
The price difference is that big, here are the prices with shipping to me.
Replikeo = $380.24
ReprapPro = $710.99
So it is a big difference. So with the extra $330 what parts would I need to get and upgrades to end up with a better printer than I would start with from RepRapPro?
I love to tinker with stuff and mod it and make it better so I'm good with that. I know I would like to add the touch display and maybe a dual extrusion head. Other than the upgrades what parts should I just replace right away with better parts?
Thanks again
Re: Looking to buy 3D printer and looking at Ormerod 2 December 10, 2015 07:55PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 02:50AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 05:42AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 07:02AM |
I'd also suggest getting a triangular aluminium bed support, which allows you to set a level bed that rarely needs readjusting. It is not necessary to use borosilicate glass - normal float glass is perfectly adequate. Or do as I did and use a thick aluminium plate.Quote
1pennyshort
... a borosilicate glass plate would be a good idea, the plexiglass they included was bowed from the start; the aluminum x-arm as recommended above; assorted spare M3 nuts and bolts, just in case, I had some missing pieces I had to scramble for.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 07:48AM |
dmould
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 08:02AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 09:46AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 10:56AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 11:04AM |
dmould
The aluminium bed support may not be needed for the Ormerod 2 - my experience is with the Ormerod 1 so I was probably in error suggesting that as it would appear that the Ormerod 2 has corrected the design shortcomings of the Ormerod 1 bed support.
My suggestion would be to make the printer from the kit as supplied (which will get you printing), and then upgrade the parts you feel you need. DC42's sensor makes it a little more convenient to set up the printer at the start of every print but will not improve print quality. The difference between the old & new Duet boards are unlikely to be at all significant for you (it does not affect printing) - certainly not worth the expense of getting a new Duet board as an extra item. To print hotter plastics you will need to replace a few of the PLA printed parts that are "in the line of fire" of the heat from the hotend and heated bed - X carriage, hotend, fan parts, extruder parts. The PLA parts should however last long enough for you to get those printed in ABS so you don't need to get anything up-front. My suggestion is to first print those parts in PLA, then in ABS. That way, if the original PLA parts fail during the hotter ABS printing, you will have spare PLA parts to allow you to try again. I've slowly replaced most of the original PLA parts with ABS. You will also find several modified designs for various printed parts. IMO the gears for the Z screw and extruder are well worth changing to the herringbone gear design, and there are better extruder designs available to print.
If the kit is supplied with a PC power supply, I would recommend replacing it with a dedicated 12V PSU, such as a 30A LED PSU. To print with a hotter bed (as needed for ABS), you will find that the voltage needs to be turned up a volt or two else the bed struggles to reach the correct temperature. Most dedicated 12V PSUs have an adjustment where you can do that. Again, probably easiest to get printing with what is supplied in the kit first, and then you can make a more informed decision.
Dave
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 12:34PM |
brlowe
With the ormerod 2 do I need the triangular aluminium bed support? Can someone provide a link as I'm not sure what it is?
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 12:56PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 01:23PM |
dc42
One point to note: if you will be using a PanelDue, do not use the external 5V linear regulator that will be supplied with your Replikeo Duet. It can't supply enough current without overheating. Use the on-board 5V switching regulator instead, and use a multimeter to verify that it is producing 5V.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 01:45PM |
brlowe
... IR board..
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 02:22PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 02:53PM |
Treito
@Erik You should mention that this is not the Mini-IR-sensor board. As far as I know is that your version not available anymore.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 03:09PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 03:14PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 04:43PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 11, 2015 04:50PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 12, 2015 02:11AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 16, 2015 09:12AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 16, 2015 01:20PM |
