Aluminium part for Ormerod January 08, 2014 04:51AM |
Re: Aluminium part for Ormerod January 08, 2014 05:07AM |
Re: Aluminium part for Ormerod January 08, 2014 09:30AM |
Re: Aluminium part for Ormerod January 08, 2014 01:15PM |
Re: Aluminium part for Ormerod January 08, 2014 01:53PM |
Treth
@Joar107, looks good! I might need the same.......
Only suggestion is the slots in the X arm for the extruder feeds. We are all using the centre slot, BUT if you try using the slot nearest the vertical arm the feed does not fit, you cannot perform the rotate of the feeder to fit the slot due to the bearing mount on the z axis.
Re: Aluminium part for Ormerod January 08, 2014 03:25PM |
I will move it the slot out a couple of mm that will help, actually I am using the inner slot to have less stress on the x-axis. It might be better to set a second "x" axis that doesn't move then it could be possible to ad 5 without putting any weight on Z.Quote
Treth
Also the slots are too close when you have 3 extruders (my rough test) to allow insertion and removal except in sequence from the Z axis end.
Easy cure is not to have the lip on the slots (mine are gradually breaking off!) to allow vertical insertion, or space out the slots!
What software did you use to produce your designs?
Re: Aluminium part for Ormerod January 08, 2014 03:46PM |
Re: Aluminium part for Ormerod January 08, 2014 05:05PM |
Re: Aluminium part for Ormerod January 08, 2014 07:26PM |
dc42
I have the same problem with the MDF bed sagging substantially in both back corners. I am planning to remake it in 3mm alu plate in a trapezoidal shape, leaving out the front corners, but your design looks nicer and might be lighter.
Re: Aluminium part for Ormerod January 09, 2014 05:47AM |
Re: Aluminium part for Ormerod January 09, 2014 05:50AM |
Re: Aluminium part for Ormerod January 09, 2014 06:05AM |
Re: Aluminium part for Ormerod January 09, 2014 07:54AM |
Re: Aluminium part for Ormerod January 09, 2014 07:59AM |
Joar107
I have made some changes to the bed, now it is only 1 laser part, 5 mm thick and the width of the ribs is 6mm. As Erik suggested I have printed the tab for the end stop. Let me know what you think I am eager to get this in production
/Joar#25
Re: Aluminium part for Ormerod January 09, 2014 09:31AM |
Agree looks much better now!Quote
kwikius
Joar107
/Joar#25
Maybe thicken the part where the holes are so total material area in cross section is uniform at section through holes and add some material at joints ( radiused in) ?
regards
Andy
Re: Aluminium part for Ormerod January 09, 2014 01:54PM |
Re: Aluminium part for Ormerod January 09, 2014 03:09PM |
Re: Aluminium part for Ormerod January 09, 2014 04:52PM |
Re: Aluminium part for Ormerod January 09, 2014 05:15PM |
Re: Aluminium part for Ormerod January 10, 2014 02:45AM |
I have printed the design I had in my last post seems good, will not be able to try it until I have made the laser cutted bed....Quote
Ormerod187
if you can help .... Imagine a bullet that has to start .... release the load on the two bearings?
the most we can be fast more things we can do even more precisely
Re: Aluminium part for Ormerod January 28, 2014 06:42AM |
Re: Aluminium part for Ormerod January 28, 2014 06:47AM |
Re: Aluminium part for Ormerod January 28, 2014 07:15AM |
Re: Aluminium part for Ormerod February 03, 2014 04:00AM |
Re: Aluminium part for Ormerod February 03, 2014 04:24AM |
Re: Aluminium part for Ormerod February 03, 2014 04:27AM |
ormerod168
No twisting x-axis = no variating in nozzle hight, glass again flat (the bulged glass illusion), bed stable as it should be, 3 point bed spring adjustment - well done, bravo!
Erik
Re: Aluminium part for Ormerod February 03, 2014 04:59AM |
dc42
ormerod168
Erik
Bulging glass is not entirely an illusion. If it were, then you would get the same amount of "bulging" at all y-axis positions. I get more at Y=100 than I do at Y=0 or Y=190.
Re: Aluminium part for Ormerod February 03, 2014 05:30AM |
