Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 16, 2014 08:15AM |
KimBrown
[attachment 28714 dccoverOK.jpg]
Hi Dave, I think the best thing to do would be for me to place a Square hole in the cover where the inductor sits as it is encased in a plastic casing, so already insulated... (5mm x 7mm approx). The cover is 5mm deep, so I don't want to make it deeper.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 16, 2014 08:20AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 16, 2014 09:50AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 16, 2014 04:44PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 17, 2014 11:14AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 19, 2014 01:07AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 19, 2014 04:42AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 20, 2014 12:26PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 22, 2014 11:33AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 22, 2014 09:08PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 24, 2014 06:07AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 24, 2014 03:36PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 24, 2014 04:18PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 24, 2014 05:40PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 24, 2014 05:42PM |
KimBrown
DC42 Probe's Safety Cover
One minor revision. Countersink on holes increased.
t.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 24, 2014 07:41PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 25, 2014 02:34AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 25, 2014 05:03PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 25, 2014 05:44PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 25, 2014 05:50PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 25, 2014 05:52PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 25, 2014 05:56PM |
stevelup
Rear left, rear right, front right and dead centre all perfect with a feeler gauge. Front left is 0.5mm low. I really don't know how or why this is possible, so I was hoping the bed compensation would sort this last little defect out. Maybe we need an x-shaped bed instead so all four corners can be levelled...
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 25, 2014 06:04PM |
stevelup
- Is the bed level mechanically?
It's as level as I can get it. I'm using your brilliant aluminium part. Rear left, rear right, front right and dead centre all perfect with a feeler gauge. Front left is 0.5mm low. I really don't know how or why this is possible, so I was hoping the bed compensation would sort this last little defect out. Maybe we need an x-shaped bed instead so all four corners can be levelled...
The automatic levelling just doesn't seem as precise as doing it by hand. I guess I'm just being lazy! It seems to do it very quickly - I wonder if some more precision could be eked out of the process.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 25, 2014 06:52PM |
dc42
You can check how well the bed levelling probing is working like this. First, execute M561 to clear the bed transform. Then go to your first M557 probe point, raise the nozzle to 5mm, and execute G30. This is equivalent to homing the Z axis at that point, except that it doesn't actually put the nozzle at Z=0. Then check how accurate the height is, e.g. by doing G0 Z0 and checking that the probe is just touching/just clear of the bed. Repeat for the other 3 points
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 25, 2014 07:19PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 05:00AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 05:11AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 08:14AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 08:20AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 08:49AM |
