Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 12:36PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 12:50PM |
Le-Seaw
okay
and what is P for the heatbed?
3?
so the new must then M305 P? T100000 R1000 B4066 H14 L-11
and the thermistor in hotend is 10 too low.
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 01:07PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 01:20PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 01:34PM |
Sardi
EDIT: Also, when its not printing, instead SD Printing, it goes "Not SD Printing" every second.
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 01:48PM |
dc42
1. Looks like Pronterface must be sending the M27 command (which is deprecated according to the firmware source code) at regular intervals, because that is the only command that generates the "SD printing" and "Not SD printing" responses, and the web interface never sends that command (I've checked). But I don't understand why it is only showing it with the new firmware and the web interface connected.
dc42
2. You should not be getting network connection error messages every second. What is your networking set-up - is the Duet connected to the PC via cables, wireless, powerline or what? Are you familiar with Wireshark, and if so, can you post a Wireshark capture of the network traffic to the Duet when attempting the initial connection after a reset?
dc42
It looks like I need to do some more testing with Pronterface as the main user interface. Most of my testing is done using the web interface. I often connect Pronterface, but usually only to monitor whether the firmware is generating any error messages. I've never seen it repeatedly say "SD card printing" or "Not SD card printing".
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 03:54PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 03, 2014 02:16PM |
dmould
I've always found that Pronterface only stops updating temperatures while the Duet is waiting on an M116 command (at the very time you would be interested in seeing the progress!). If "watch" is ticked, then monitoring is resumed after printing resumes (i.e. temperatures attained)Quote
ormerod168
In Pronterface, with any firmware I have used, monitoring of temperatures stops the moment I start a SD print, it doesn't bother me, to monitor anything you have lost control over don't make any sense
And fair enough, If I wanted to change any ingredients (slicing) I should have done so before putting the cake in the oven (send to print)
Erik
.. and you do still have some control - I can set a new temperature for bed or hotend from Pronterface in the normal way at any time during a print, which is handy when you want to experiment with how different temperatures affect the quality on the fly, or change the temperature at specific parts of a print (I find bridges work better at a lower temperature than I usually print at). The web interface does not allow you to change temperatures during a print using the buttons, but you can still change the temperature mid-print by sending the appropriate command in the G code window.
Dave
(#106)
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 09:07AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 09:22AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 09:53AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 12:01PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 12:27PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 01:49PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 02:34PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 05:29PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 06:24PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 04, 2014 07:17PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 05, 2014 02:27AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 05, 2014 04:00AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 05, 2014 05:25AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 05, 2014 05:34AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 05, 2014 06:14AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 05, 2014 07:15AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 05, 2014 09:59AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 05, 2014 11:47AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 05, 2014 01:56PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 June 27, 2014 02:54AM |
Joar107
Hi I wonder if it hard to change the thermistor type in the firmware I have a new hot end that I would like to use, [files.e3d-online.com]
And it use a different thermistor Semitec 104GT2.
/Joar
Re: Updated firmware 0.58d-dc42 and web interface 0.73 June 27, 2014 04:56AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 June 27, 2014 07:54AM |
