anti-vibration stands for ormerod May 05, 2014 05:09PM |
Re: anti-vibration stands for ormerod May 09, 2014 02:51AM |
Re: anti-vibration stands for ormerod May 09, 2014 12:59PM |
Re: anti-vibration stands for ormerod June 06, 2014 12:13PM |
Re: anti-vibration stands for ormerod June 06, 2014 12:21PM |
Re: anti-vibration stands for ormerod July 01, 2014 08:30AM |
Re: anti-vibration stands for ormerod July 02, 2014 02:50AM |
Re: anti-vibration stands for ormerod July 02, 2014 03:01AM |
Re: anti-vibration stands for ormerod July 02, 2014 03:38AM |
jstck
As mentioned in the first post, the "rear" goes under the Z axis, and the "rear left" goes under the Y motor/bracket. I found neither of those fit too well, but I just sort of placed them somewhere it seemed decent.
However, on a flat surface, the "rear left" one in my case would barely touch the printer and would easily come out, so I just removed it. And since there was a lot more weight on the "rear" one, it would tilt a lot in that direction. I took out the inner "loop" of the two front ones, so I'm just using half the mount for those. That makes the printer sit level, and it seems to stand securely on just three feet. It doesn't move about noticeably when I move the bed to end positions though I haven't made any extremely large and heavy prints on it...
In any case, it did make the printer a _lot_ less noisy. I had not expected it to make nearly as much of a difference as it did.
Re: anti-vibration stands for ormerod September 02, 2014 09:37AM |
Re: anti-vibration stands for ormerod September 02, 2014 10:22AM |
barkerboy
I'm having a bit of a problem with the prints lifting at the ends ( in the loops).
I think it may be because they're so thin. anyone else had these problems, anyone got any suggested solutions?
Re: anti-vibration stands for ormerod September 02, 2014 10:57AM |
barkerboy
Re: anti-vibration stands for ormerod September 02, 2014 11:11AM |
Re: anti-vibration stands for ormerod September 02, 2014 02:43PM |
Re: anti-vibration stands for ormerod September 02, 2014 04:30PM |
Re: anti-vibration stands for ormerod September 24, 2014 03:05PM |
Re: anti-vibration stands for ormerod September 25, 2014 05:56AM |
Re: anti-vibration stands for ormerod October 12, 2014 07:58AM |
Re: anti-vibration stands for ormerod October 12, 2014 02:56PM |
Re: anti-vibration stands for ormerod October 12, 2014 05:13PM |
Amsterdamman
[attachment 41779 IMG_1179.jpg]
Ok, these work GREAT! Much quieter while printing and it raises the under bed wiring higher off the table. I would rename the back feet since they are very non intuitive. It may be more clear to call them Y motor stand and Z motor stand (or foot). These should be on thingiverse as well! If you don't want to upload them I can do it giving you the credit for the design. Thanks for making these standing anti-vibrating base feet!
Re: anti-vibration stands for ormerod October 12, 2014 06:15PM |
