Why wasnt the middle of the shape filled with filament? May 07, 2014 05:50AM |
Re: Why wasnt the middle of the shape filled with filament? May 07, 2014 06:00AM |
Re: Why wasnt the middle of the shape filled with filament? May 07, 2014 06:07AM |
Re: Why wasnt the middle of the shape filled with filament? May 07, 2014 06:57AM |
Re: Why wasnt the middle of the shape filled with filament? May 07, 2014 07:16AM |
Re: Why wasnt the middle of the shape filled with filament? May 07, 2014 09:48AM |
Re: Why wasnt the middle of the shape filled with filament? May 07, 2014 10:47AM |
Re: Why wasnt the middle of the shape filled with filament? May 07, 2014 10:59AM |
Re: Why wasnt the middle of the shape filled with filament? May 07, 2014 02:05PM |
bitbang
Got the same effect while printing a lid for a small box; concentric offers a nicer surface finish.
There must be some reason I'm unable to see preventing extrusion of more plastic (and hence larger width) for that very last trace only; any insight?
Re: Why wasnt the middle of the shape filled with filament? May 07, 2014 06:36PM |
Re: Why wasnt the middle of the shape filled with filament? May 08, 2014 04:45AM |
Re: Why wasnt the middle of the shape filled with filament? May 08, 2014 08:23AM |
It's only one layer that is affected. I would expect an item designed to be watertight would be several layers thick - and if not use a more suitable fill pattern. It's the nature of the beast that you cannot rely on every layer being completely filled, only that gaps will be in different places on different layers.Quote
ellipse
What is aesthetics for some is function for others; if I were to print a device meant to be watertight, it would make sense to have a warning that some surface is not completely filled.
Re: Why wasnt the middle of the shape filled with filament? May 08, 2014 04:22PM |
dmould
"It's the nature of the beast that you cannot rely on every layer being completely filled"
Re: Why wasnt the middle of the shape filled with filament? May 10, 2014 08:28AM |
