I am using 0.59a-dc42 and reprap.htm/js 0.74.
I seem to be having issues with my files for homing both x and y. Both axis now have a trip switch. and the problem repeats both using Pronterface and the Web interface.
I know its my coding but I cant see it for looking.
I turn the printer on, then connect it (via either pronterface or the web interface)
Then run homeX and then homeY
Both files work perfectly doing what I want them to do
I then run my Setbed, again that does what I want it to do.
BUT
If I then try and run my two homing files again (dont ask why but I thought I would try it!!) they ignore the G1 X-240 (or Y240) and assume the switch has been tripped and do the last two lines of the code.
If I go thru the same routine of turning the printer on, connecting it and run homex and home y WITHOUT running setbed.g I can run both the homing files time and time again with perfect results, doing what they should do. Until I run Setbed.g
Help
; HOMEX
G91; Relative positioning
G1 Z5 F200
G90; Absolute positioning
G1 X-240 F2000 S1
G92 X-13
G1 X10 F2000
; HOMEY
G1 Z5 F200
G1 Y240 F2000 S1
G92 Y210
G1 Y24 F2000
; SETBED
M561; Resets Bed plane
G30 P0 X10 Y24 Z0.0; Bed Compensation 1st point
G30 P1 X26 Y188 Z-0.3
G30 P2 X194 Y188 Z1.7
G30 P3 X194 Y28 Z1.8 S
G1 Z20 F200
G1 X100 Y105 F2000
I also thought I would try M119; which
"...Returns the current state of the configured X, Y, Z endstops..."
That didnt seem to work for me.
Tim
Firmware: 059d, Web Interface: 0.8
75mm Diameter Extruder Drive
100mm test model
Filament spool holder and rotating dispenser
