New firmware 065g-dc42 and web interface 0.91
Posted by dc42
Re: New firmware 065g-dc42 and web interface 0.91
July 06, 2014 06:46PM
Bugger.... oops.... Ok I'm dyslexic KO..... lol
Where did that slip in from.... Thanks for that... Guessed it was something stupid.
I've altered that to 57' now, I'll try again....
It was 57' before, but it was the T0 error messing it up in Slic3r...then.. how I changed it to 95' I don't know....
Will try again now... Thanks.... (busy kicking myself here)....
July 07, 2014 06:41AM
This version seems to work a treat David.... I guessed something minor was wrong in my setup, but for the life of me I couldn't see it...
Many thanks for your help.
Just got a dodgy reel of filament to contend with now....
Kim..
July 07, 2014 07:48PM
Using this Firmware and the Big Blue has produced these perfect openings (Bridges 30&40mm).
In the attached picture it may look like there are loose straigth strands, but these edges are actualy Chamfered at 45', and perfect.
The center oblong, and the cut out at the front are where a clamp fits for the phone clamp, as the phone sits above the Radio Transmitter...
The other cut outs are for the phones buttons, and Iphone power connector.
Edited 1 time(s). Last edit at 07/07/2014 07:49PM by KimBrown.
July 23, 2014 03:13PM
dc42
Have you tried pressing control-shift-J to get the JavaScript console? There will probably be some error messages.
Ok it happened again right after Home All finished.
Pressing Ctrl+Shift+J dose not do anything in that tab at all.
Now I'm using Google Chrome but it was the same with Chromium
Pressing Ctrl+Shift+J in this tab works and brings up the console.
Essentially it seams like that tab is locked up.
I'm still on 65j-dc42 with webinterface 0.95
Will upgrade to latest and see if this problem persists.
August 18, 2014 11:08AM
ok new stupid problem now..
i had the new firmware running but it wouldnt home the X axis, it just kept trying to run into -ve and obviously hitting the end and jamming. so with the new firmware and web interface running hapily i went to look into the issue. the reprap troubleshooting said that having updated the firmware to load the new files from the current firmware to make sure everything is up to date. so i get all the files from the SD image folder bar the www files and copy them to the SD card. now when i try and run the printer nothing happens.
please oh great and powerful DC what have i broken and how can i un-break it.
Thanks
Blake
August 18, 2014 11:28AM
My guess is that despite the title of this thread, you are now using 0.78 series firmware, and you need to move the blue z-probe wire to a different pin on the expansion connector. See [forums.reprap.org].
Edited 1 time(s). Last edit at 08/18/2014 11:28AM by dc42.
August 18, 2014 11:33AM
ahh, that might solve that problem. but how do i get the web interface back up. where do i get the sys and Gcode folders from to work with the latest firmware?
August 18, 2014 12:13PM
ahahahha I'm sorry for wasting your time DC I'm such a numpty. I hadn't re set my IP settings having copied over the files...
