Re: Experimental firmware 0.78a-dc42 July 10, 2014 04:03PM |
Re: Experimental firmware 0.78a-dc42 July 10, 2014 05:36PM |
Re: Experimental firmware 0.78a-dc42 July 10, 2014 05:45PM |
Re: Experimental firmware 0.78a-dc42 July 12, 2014 01:03PM |
dc42
* M208 command allows you to set axis minimum positions (e.g. a negative x-axis position) as well as maximum positions.
appjaws1
You suspected an intermittent microswitch connection, but I have checked and rechecked, the connections are tight, also I did mention that the x movement was only a few steps in the middle, it did not travel to the homing point.
Re: Experimental firmware 0.78a-dc42 July 12, 2014 01:18PM |
planar
Could it be that your previously existing M208 command, by not specifying the minimum positions, was confusing the firmware?
Re: Experimental firmware 0.78a-dc42 July 12, 2014 01:20PM |
planar
Re: Experimental firmware 0.78a-dc42 July 12, 2014 03:34PM |
dc42
I'd still like to know what was the cause of your Y-homing problem, as switching to RRP's homey.g file shouldn't have made any difference. I still suspect an intermittent microswitch connection,
Re: Experimental firmware 0.78a-dc42 July 12, 2014 05:49PM |
planar
The source of the problem was the bed plane compensation. If I tried to home after setting the bed plane compensation, it would crash.
Re: Experimental firmware 0.78a-dc42 July 13, 2014 07:20AM |
dc42
The workaround is to make sure the bed is high enough off the bed when doing a homing move, and to ensure that the correct z-probe type is selected before doing a homing move. The homex.g and homey.g files move the head up 5mm, but do not set the Z probe type.
Re: Experimental firmware 0.78a-dc42 July 13, 2014 07:41AM |
Re: Experimental firmware 0.78a-dc42 July 13, 2014 09:27AM |
ezwul
Hi DC
Is there a file size limit on the config.g?
Lloyd
Re: Experimental firmware 0.78a-dc42 July 13, 2014 09:46AM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 04:14AM |
appjaws1
I have just started my ormerod from cold with your home files. The first thing I did was to raise Z by 10mm and then selected setbed.
The bed flew to the right until it couldn't go any further and then went to the left but stopped short of the microswitch. Automatic bed levelling did not happen and eventually the nozzle went to X100 Y100 when the bed temperature was reached, and turned the hot end heater on and just sat there.
So I agree something is preventing automatic bed compensation from working but I don't think it is the Z height
I tried it a second time with the same results.
This is my setbed
Re: Experimental firmware 0.78a-dc42 July 15, 2014 04:35AM |
G91 G1 Z3 F200 G1 X5 F2000 G1 Y220 F2000 S1 G90 G1 Y0 F12000 G91 G1 X-5 F2000 G1 Z-3 F200 G90
Re: Experimental firmware 0.78a-dc42 July 15, 2014 06:05AM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 08:51AM |
appjaws1
I still don't really understand why this method is better than the reprap original.
Re: Experimental firmware 0.78a-dc42 July 15, 2014 11:34AM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 03:18PM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 03:29PM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 03:38PM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 04:07PM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 04:54PM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 06:02PM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 06:22PM |
Re: Experimental firmware 0.78a-dc42 July 15, 2014 11:25PM |
Re: Experimental firmware 0.78a-dc42 July 24, 2014 05:08PM |
Re: Experimental firmware 0.78a-dc42 July 24, 2014 06:15PM |
Sardi
Hey.
After homing X, when I press HEAD 1 via Web interface, the X moves to 0.1.. ?
Re: Experimental firmware 0.78a-dc42 January 24, 2015 11:35AM |
Re: Experimental firmware 0.78a-dc42 January 24, 2015 11:40AM |
Re: Experimental firmware 0.78a-dc42 January 24, 2015 12:27PM |
