Cura extrusion rate too high September 17, 2014 11:09AM |
Re: Cura extrusion rate too high September 17, 2014 11:22AM |
Re: Cura extrusion rate too high September 17, 2014 11:27AM |
Re: Cura extrusion rate too high September 17, 2014 11:53AM |
jstck
I think the cura engine can be configured to output relative values, but as far as I know there is no way to set that in the GUI.
Re: Cura extrusion rate too high September 17, 2014 11:59AM |
Re: Cura extrusion rate too high September 17, 2014 12:20PM |
dmould
...I have attached it to this post (I hope the original poster doesn't mind) - to use, download it and put it into the "Plugin" subdirectory under your "Cura" folder..
Re: Cura extrusion rate too high September 17, 2014 12:31PM |
ormerod168
dmould
Frank's original archive (that I linked to upstream) had ini files included, I installed them over the old version of Cura's ini's, but are they needed? - and will the work with a newer version of Cura?
[attachment 40408 franksplugin1.JPG]
README.md only read: Cura Plugin for RepRapPro Ormerod support (convert absolute to relative extrution values etc.)
Erik
Re: Cura extrusion rate too high September 17, 2014 01:14PM |
dmould
Wrong directory. Look for a directory call "plugins" under Cura (see attached screenshots of my file explorer)
Dave
Re: Cura extrusion rate too high September 17, 2014 01:47PM |
Re: Cura extrusion rate too high September 17, 2014 01:59PM |
Re: Cura extrusion rate too high September 18, 2014 10:42AM |
ormerod168
dmould
Dave
I think we have a communication problem :-)), yes I know Frank's plugin should be in the plugins folder, but the ini files in Frank's original archive, should they be installed, as in overwrite the original Cura file or not?
Left: Cura directory - Right: Frank's original archive
The ini's in the archive, to install or not install, that is the Q
[attachment 40416 franksplugin.2.JPG]
Erik
