Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 12, 2014 11:43AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 12, 2014 11:55AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 12, 2014 12:40PM |
dc42
To upgrade from 0.65 to 0.78 series firmware you need to:
1. Update your config.g file. In particular, you need to put an M563 command in it to define the print tool.
2. Connect your Z probe to the new pins on the expansion connector.
3. Reverse the X motor loom on the Duet so that it is the same way round as the other motor looms, or put M569 P0 S1 in config.g.
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 12, 2014 12:51PM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 13, 2014 07:05AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 13, 2014 09:14AM |
KimBrown
Can I tell the Laptop to only have one IP address on Ethernet Wired connection (a static IP address, I think) so I can just network the
Laptop and the printer via cable, no matter what the WiFi IP address is. I'm very rusty on networking, as the majority of it is all automatic
these days...
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 13, 2014 11:47AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 13, 2014 01:36PM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 18, 2014 05:52AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 18, 2014 06:20AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 18, 2014 07:08AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 18, 2014 07:46AM |
Crouchy
Dave,
One slight bug in the web interface here:
From the GCode file: ; filament used = 11887.6mm (28.6cm3)
I uploaded this file and clicked the info button. this is what it told me:
File information for gcodes/RFWS1214_fixed.gcode
Object height
115.44mm
Filament Needed
11887600mm
Layer height
0.24mm
Generated by
Slic3r 1.1.7 on 2014-12-18 at 21:11:08
File size
1.345Mb
I'm wondering where I can buy an 12Km roll of filament.
Paul
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 18, 2014 08:08AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 19, 2014 01:12AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 19, 2014 01:03PM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 19, 2014 01:41PM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 19, 2014 02:06PM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 19, 2014 02:27PM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 20, 2014 05:10AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 20, 2014 05:30AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 21, 2014 12:49PM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 21, 2014 01:09PM |
Pointy
Is there any where you could squeeze in the current X/Y printing/movement speed on the web interface? Ideally if possible this would take into account the speed slider position.
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 22, 2014 05:01PM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 28, 2014 03:48PM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 December 28, 2014 04:53PM |
KimBrown
... I noticed that the Extruder heater was coming on randomly for about a second or two, then off, and then later doing the
same.... Just wondered if this was something in the firmware checking that the heater and thermistor were working.
Kim..
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 January 01, 2015 10:09AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 January 11, 2015 07:18AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 January 11, 2015 10:40AM |
denshine
hi!
i have upgraded but the z probe dosent work..
i read someware that i have to rewire the probe (in a update somweare down the line)
but i cant find the wiering diagram (picture of the conections)
do anyone have a link to the pic?
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 January 30, 2015 03:56AM |
Re: New experimental firmware 0.78v-dc42 and web interface 1.03 January 30, 2015 04:05AM |
