New experimental firmware 1.00h-dc42 February 11, 2015 07:49PM |
* Macros can now call other macros, up to a total file nesting limit of 5. This also means that macros can use G28, T1 and other commands that invoke macros.
* Support for faster print pausing, and for pause.g and resume.g macros. The position and fan speed are automatically restored prior to resuming a print after a pause Thanks to zombiepantslol for the idea (but I am using a different implementation).
* X and Y axes are are homed simultaneously, if you use my homeall.g file.
* Supports the extra web server responses required by zombiepantlol's web interface. You can use either that interface, or continue to use my 1.04 version.
* Incorporated zombiepantlol's changes to the Network layer and FTP server
* Support added for message log on PanelDue (coming soon to PanelDue firmware)
* Minor improvements to the new Move code
Re: New experimental firmware 1.00h-dc42 February 12, 2015 12:55PM |
Re: New experimental firmware 1.00h-dc42 February 12, 2015 01:43PM |
fotomas
Tried to use zombiepantslol www folder. With no sucess, at all. The browser do not get any response.
It may not be the right place to ask but... I just added his www folder from github to the SD-card. Is that how it is supposed to be done?
Re: New experimental firmware 1.00h-dc42 February 12, 2015 02:22PM |
zombiepantslol
fotomas
Eww, no, use the files from this repository: [github.com]
Re: New experimental firmware 1.00h-dc42 February 12, 2015 02:43PM |
Re: New experimental firmware 1.00h-dc42 February 12, 2015 02:52PM |
fotomas
A humble question; what is the idea behind the files I used?
Re: New experimental firmware 1.00h-dc42 February 12, 2015 06:23PM |
Re: New experimental firmware 1.00h-dc42 February 12, 2015 06:38PM |
fotomas
It seems like the M557 coordinates for bed calibration are not used. I have checked and rechecked my settings.
When sending G32 it moves to X60 Y0 dispite my config G setting M557 P0 X28 Y15.
Re: New experimental firmware 1.00h-dc42 February 12, 2015 06:54PM |
pantau
Looks like with 1.00h the amount of g-code files you can have on the SD-card somehow changed? I first noticed that after uploading a new file (with the webinterface) it didn't show up in the list. Looking closer I noticed that I have less files shown, even if they are still on the card. E.g my setbed.g suddenly was not shown anymore in the control page. Reverting back to 1.00g and all files are visible again. I know there is a limit on files (I have about 55 in the /gcodes dir), but is it design intent in 1.00h that the limit is lowered?
Re: New experimental firmware 1.00h-dc42 February 13, 2015 10:14AM |
Re: New experimental firmware 1.00h-dc42 February 13, 2015 03:08PM |
Jermain
So I flashed the new firmware 1.00h-dc42 but in each WebControl after the Version 0.65 I get the same issue, that the Hot End Temperature wasn´t shown correctly.
Re: New experimental firmware 1.00h-dc42 February 13, 2015 03:28PM |
Re: New experimental firmware 1.00h-dc42 February 13, 2015 04:22PM |
Re: New experimental firmware 1.00h-dc42 February 13, 2015 04:47PM |
Re: New experimental firmware 1.00h-dc42 February 13, 2015 05:37PM |
Re: New experimental firmware 1.00h-dc42 February 13, 2015 07:40PM |
Re: New experimental firmware 1.00h-dc42 February 14, 2015 03:15AM |
Re: New experimental firmware 1.00h-dc42 February 14, 2015 05:04AM |
dougal1957
Dave
Is there any way to change the operating mode of the Heaters.
ie can I in some way use bang-bang for the hotbed
I am going to be using an AC Heater with a SSR so not sure how PID control will cope.
Thanks again for all your time on this rewrite to deal with Delta Printers.
Doug
Re: New experimental firmware 1.00h-dc42 February 14, 2015 05:11AM |
Jermain
Okay, if I warmig up the Hot End I got a sign. And if the nozzle lost the Temperature the sign lost. (Temperature sign.gif)
The ADC offset is H0 L0 like the config file.
In the past the sensor show 10-15 degrees lower than the room temperature from 21 degrees. Could I change this difference with the ADC offset?
Next, I flashed the old RepRap Version 0.78c and used the Web Control v0.65 (WebControl v0.65.gif). Correct sign at startup the ormerod.
Did you have any idea?
Greetings Jermain
Re: New experimental firmware 1.00h-dc42 February 14, 2015 05:56AM |
Re: New experimental firmware 1.00h-dc42 February 14, 2015 07:01AM |
Re: New experimental firmware 1.00h-dc42 February 14, 2015 07:27AM |
Re: New experimental firmware 1.00h-dc42 February 14, 2015 08:50AM |
dc42
By default, the hot bed already uses bang-bang. So there should be no problem with using a mains powered heater and zero crossing SSR. I guess the heated bed is quite large?
You can switch between PID and bang-bang using the M301 or M304 command. A negative P term instructs the firmware to use bang-bang.
dougal1957
Dave
Doug
Re: New experimental firmware 1.00h-dc42 February 14, 2015 09:23AM |
Re: New experimental firmware 1.00h-dc42 February 14, 2015 11:07AM |
dmould
Just tried my first print with this firmware. The web interface did not find the height or total filament needed, so print time was unavailable. I'm slicing with S3D. Print seems to be going OK (still printing). I could attach the gcode if needed, but I'm guessing that the search for those parameters in an S3D file has been regressed.
Dave
Re: New experimental firmware 1.00h-dc42 February 14, 2015 11:30AM |
dc42
dmould
Dave
I accepted zombiepantlol's changes to that code, but I thought he supported S3D too. Anyway, send me a sample gcode file and I will fix it.
Re: New experimental firmware 1.00h-dc42 February 14, 2015 01:03PM |
Re: New experimental firmware 1.00h-dc42 February 14, 2015 01:15PM |
Re: New experimental firmware 1.00h-dc42 February 15, 2015 05:24AM |
Re: New experimental firmware 1.00h-dc42 February 15, 2015 05:39AM |
