Filament breaking in extruder if left overnight February 27, 2015 06:29PM |
Re: Filament breaking in extruder if left overnight February 28, 2015 03:51AM |
Re: Filament breaking in extruder if left overnight February 28, 2015 07:05AM |
Re: Filament breaking in extruder if left overnight February 28, 2015 07:19AM |
Re: Filament breaking in extruder if left overnight February 28, 2015 01:45PM |
iamburny
I have never had this happen to me, my ormerod is inside, at room temperature which doesn't usually drop below 18C....
Re: Filament breaking in extruder if left overnight February 28, 2015 01:51PM |
Re: Filament breaking in extruder if left overnight February 28, 2015 03:59PM |
Re: Filament breaking in extruder if left overnight February 28, 2015 04:38PM |
Re: Filament breaking in extruder if left overnight February 28, 2015 04:53PM |
Re: Filament breaking in extruder if left overnight March 01, 2015 03:08PM |
Re: Filament breaking in extruder if left overnight March 03, 2015 02:02PM |
dc42
For a long time I've had a problem that if I leave filament in the extruder overnight, when I try to print the next day the print fails, because the filament breaks in the extruder (or has already broken). My Mini Kossel does not suffer from this problem.
At first I thought that the filament was weakened by being pinched between the hobbed insert and the bearing for too long. I am using the modified extruders by masonstonehenge, so I thought that slackening the spring tension overnight would solve the problem. It didn't.
I'm now fairly sure that the problem is the tight radius that the filament is forced to go round to complete the 90 degree inlet turn. This would explain why the printer is able to extrude several cm of filament from the nozzle before the flow stops (because the break is several mm before the hobbed insert) and why it often breaks in several places over 1 or 2cm. The room that the printer is in gets quite cold overnight, and this may be making the filament more brittle.
There appears to me to be room to move the filament inlet to the extruder down by several mm, which would allow for a greater radius of turn and less stress on the filament. Perhaps this would solve the problem?
Another possibility might be to design the extruders to push filament horizontally in the +X direction, and make the Bowden tubes loop through 270 degree. Does anyone have any other ideas for avoiding the sharp turn?
Re: Filament breaking in extruder if left overnight March 03, 2015 03:05PM |
Re: Filament breaking in extruder if left overnight March 03, 2015 04:59PM |
Re: Filament breaking in extruder if left overnight March 04, 2015 04:01AM |
Re: Filament breaking in extruder if left overnight March 16, 2015 09:36AM |
Re: Filament breaking in extruder if left overnight March 16, 2015 03:51PM |
Re: Filament breaking in extruder if left overnight March 16, 2015 06:10PM |
Re: Filament breaking in extruder if left overnight March 16, 2015 06:47PM |
Re: Filament breaking in extruder if left overnight March 16, 2015 09:08PM |
Davek0974
Interesting but the PLA comes shipped with a bag of silica gel in the wrapper - surely that would make it worse??
I've got stuff from three suppliers and they all do it
RoSt
with the white filament that came with the printer i didnt have any problem at all, bought a 1kg black Verbatim PLA and it could brake in five places over the night. Now i have a white 1kg spool from a Swedish web-store www.kjell.com and i havent had any problem at all.
Do the color pigment have any role in this?
Re: Filament breaking in extruder if left overnight March 19, 2015 09:37AM |
Re: Filament breaking in extruder if left overnight March 19, 2015 10:15AM |
Treth
Is there a non-pigment PLA and what is its natural colour?
Also what is the effect of the pigment on the final printed product, is anyone seeing adverse affects?
Re: Filament breaking in extruder if left overnight March 19, 2015 02:26PM |
Re: Filament breaking in extruder if left overnight March 20, 2015 03:24AM |
dc42
Today I unloaded filament that I had left in the extruder for several days. There was either a break in the extruder inlet already, or one occurred as I unloaded the filament. But the filament also broke at or above the hobbed bolt, because some filament was left in the Bowden tube.
I examined the broken pieces of filament, and I found them unusually brittle. Taking a piece of filament fresh from the spool (which sits on the floor), if I try to break it then it just bends. But the pieces of filament that have been sitting in the machine or leading up to the extruder inlet snap instead.
So I think that something is making the filament brittle, and this in combination with the small radius of the extruder inlet causes it to break. I have finally got round to printing VortZA's modified feeder part with the larger radius today, so I am hopeful that this will solve the problem. As for what is making the filament brittle, I guess it could be UV light, because the room the printer is in has a south-facing window.
Re: Filament breaking in extruder if left overnight March 20, 2015 08:36AM |
VortyZA
Not sure what the final solution would be apart from different filament or unloading at night. Fortunately zombiepantslol's web interface has that lovely unload feature which makes it very easy to do!
Re: Filament breaking in extruder if left overnight March 20, 2015 08:55AM |
dc42
Re: Filament breaking in extruder if left overnight March 20, 2015 01:26PM |
Re: Filament breaking in extruder if left overnight March 20, 2015 03:08PM |
Jon Steward
Maybe it's to do with the filament contracting. i.e tightly held in the extruder as the hot end cools?
Re: Filament breaking in extruder if left overnight March 20, 2015 03:22PM |
Jon Steward
..Maybe it's to do with the filament contracting. i.e tightly held in the extruder as the hot end cools?
Just a guess.
Re: Filament breaking in extruder if left overnight March 21, 2015 10:53AM |
Re: Filament breaking in extruder if left overnight March 25, 2015 05:40AM |
