Bowden tube coming out of extruder February 28, 2015 09:31AM |
Re: Bowden tube coming out of extruder February 28, 2015 11:25AM |
Re: Bowden tube coming out of extruder March 03, 2015 08:59AM |
Re: Bowden tube coming out of extruder March 03, 2015 09:21AM |
droftarts
I think someone else did this mod ages ago...
Re: Bowden tube coming out of extruder March 03, 2015 11:05AM |
Re: Bowden tube coming out of extruder March 03, 2015 11:27AM |
droftarts
I think someone else did this mod ages ago, and shared the file. Alternatively, put a cable tie around the Bowden tube, and through the hole in the tongue.
Ian
RepRapPro tech support
Re: Bowden tube coming out of extruder March 03, 2015 01:40PM |
dc42
I'm hoping that masonstonehenge will do a variant of his spring-loaded extruder design to use a pneumatic connector. My Mini Kossel uses these and I have found them to be totally reliable - although I have read that there are different sorts and some grip the tube much better than others.
Re: Bowden tube coming out of extruder March 03, 2015 01:59PM |
Re: Bowden tube coming out of extruder March 03, 2015 02:08PM |
dc42
Re: Bowden tube coming out of extruder March 03, 2015 02:22PM |
dougal1957
dc42
Dave
You wouldn't happen to have the STL file for that extruder would you?
One tip tho is if you can pass the 4mm PTFE all the way thru the coupling and thru the extruder body and shape it so it is just clear of the hobbed drive.
Re: Bowden tube coming out of extruder March 03, 2015 02:37PM |
That's typical Whilst I'm drafting a post someone post's the info I'm after ah well it's there now just about to download it and have a lookQuote
VortyZA
dougal1957
dc42
Dave
Refer to the post before yours
Re: Bowden tube coming out of extruder March 03, 2015 02:48PM |
dougal1957
VortyZA
dougal1957
dc42
Dave
Actually I need the STL's for the complete extruder not just the spring loaded part tho that is appreciated.
Re: Bowden tube coming out of extruder March 03, 2015 02:52PM |
VortyZA
dougal1957
VortyZA
dougal1957
dc42
Dave
This extruder is composed of 2 parts, the part that attaches to the motor and the part that pivots - I might be misunderstanding your question?
Re: Bowden tube coming out of extruder March 03, 2015 03:45PM |
VortyZA
Well who would like to guinea pig this version of the spring-loaded extruder?
I don't want to post it on Thingiverse as yet, but it includes the following changes:
1) a larger radius (35mm) for dc42's sake to see if it's the tight radius that causes the filament to break overnight.
2) It has the PTFE tube going all the way through the part to just before the hobbed nut (slightly wider for those that found the hole was too small).
3) It has a 5.2mm hole into the top of the part for the pneumatic fitting. (The 5.2mm will probably print to about 5mm - your mileage may vary)
Re: Bowden tube coming out of extruder March 04, 2015 04:37AM |
dougal1957
dc42
Dave
Re: Bowden tube coming out of extruder March 04, 2015 07:52AM |
VortyZA
This link will remain active until a week or so has passed..
Link to the zip file containing stls
Disclaimer: Be aware that this is a purely test version, so there might be mistakes..
Please provide feedback.
Re: Bowden tube coming out of extruder March 04, 2015 11:13AM |
Re: Bowden tube coming out of extruder March 04, 2015 04:02PM |
Re: Bowden tube coming out of extruder March 06, 2015 07:49AM |
dc42
VortyZA
Thanks! However, as the fitting is M5 threaded, the hole needs to be about 4.5mm so that I can M5 tap it - unless you think there is room for a nut. Do you mind adjusting the STL?
Re: Bowden tube coming out of extruder March 06, 2015 09:22AM |
VortyZA
I've made it exactly 4.5 on the 3d drawing - I always find with my slicer that I have to make every inner hole diameter about .4mm larger to make it perfect, but let me know if that's the right size?
Updated .stl
Is the PTFE tube hole large enough?
Re: Bowden tube coming out of extruder April 07, 2015 02:01PM |
Re: Bowden tube coming out of extruder April 10, 2015 11:52AM |
Re: Bowden tube coming out of extruder April 10, 2015 12:29PM |
Re: Bowden tube coming out of extruder April 14, 2015 08:59AM |
Re: Bowden tube coming out of extruder April 18, 2015 11:57PM |
Re: Bowden tube coming out of extruder April 19, 2015 04:08AM |
Re: Bowden tube coming out of extruder May 11, 2015 02:22AM |
Does anyone have an stl file for the other half of this modified extruder. The 'updated stl' only contains the modified half for the update to the hole for the pnuematic connector. The original post presumably with both halves has been deleted from dropbox. Thanks for your helpQuote
I've made it exactly 4.5 on the 3d drawing - I always find with my slicer that I have to make every inner hole diameter about .4mm larger to make it perfect, but let me know if that's the right size? Updated .stl Is the PTFE tube hole large enough?
Re: Bowden tube coming out of extruder May 11, 2015 08:07AM |
Re: Bowden tube coming out of extruder May 11, 2015 04:06PM |
Re: Bowden tube coming out of extruder May 12, 2015 06:00AM |
