web control with RepRap Firmware Version 1.09 May 05, 2015 04:18AM |
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 04:51AM |
xiandhq
Hi,everyone:
I updated my firmware to version 1.09 a.m,The printer worked well with pronterface,but web could not connect with the machine via the local network.what should I do? I also have changed name of my machine as the picture...what should I write in the browser address bar.Thank you in advance.
[attachment 54125 11.jpg]
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:02AM |
dougal1957
xiandhq
Hi,everyone:
You have to make the default gateway in the M554 line to be the same as your router address and you need to set your IP for the printer to an unused address on your network in the M552 command you currently have it set to 0.0.0.0 which is not valid.
Until you get these setup correctly you will never connect to the Web IF
Doug
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:06AM |
xiandhq
dougal1957
xiandhq
Hi,everyone:
Doug
Thank you for your replying,
I have made the default in the M554 line to be the same as my router address,but the introduction says that “Connecting the machine via the local network is much simpler, since DHCP and NetBIOS have been fully implemented. This allows users to connect to their machine without knowing the local IP address, but instead using the machine name in the browser address bar.”
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:14AM |
dougal1957
xiandhq
Hi,everyone:
Doug
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:21AM |
zombiepantslol
dougal1957
xiandhq
Hi,everyone:
Doug
That isn't correct, passing 0.0.0.0 as the IP parameter enables DHCP. xiandhq, can you post the start-up log of your printer? It would be helpful to see if the firmware was able to acquire a valid IP address. But you could also try to connect to it via its NetBIOS name which should be "MyRepRapProorme" in your case.
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:33AM |
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:35AM |
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:36AM |
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:40AM |
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:44AM |
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:50AM |
zombiepantslol
Try to open [192.168.1.104] - connecting via the NetBIOS/DHCP name is a better idea though, because that IP may change after a while.
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 06:00AM |
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 05:55PM |
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 11:20PM |
bartdietrich
Hi all,
Sorry for butting in but given the subject of this thread I thought this would be the right place to do so.
I've also just upgraded to the new 1.09 RepRap firmware and copied all relevant files from the SD-image folder to the SD card (including everything in www). I see and can connect (eventually) to the printer via the new web interface. The printer controls work but anything to do with SD file operations doesn't. That is, I can't delete files from the card or print them, or upload and print (when I click the relevant buttons nothing happens). I can upload and print from Pronterface and when I do, the web interface is aware of it (i.e. it displays print progress etc).
I use Opera and file operations used to work in version 1.04. I did merge the new www folder with the old one (replacing existing files) rather than replacing it completely in case that's relevant.
Any ideas?
Thanks,
Bart
Re: web control with RepRap Firmware Version 1.09 May 05, 2015 11:40PM |
zombiepantslol
Looks good, but you haven't updated your /www directory yet. Grab a copy of the new web interface from the SD image directory and copy those files to your SD card (you may even use FTP for this). If you want to try out FTP, download FileZilla, set up a new server with that IP address, choose any username you like (anonymous or root for example), enter the password from your config.g file (default is reprap) and limit the number of concurrent connections to 1 (this is important if you upload more than one file at once!).
Re: web control with RepRap Firmware Version 1.09 May 06, 2015 07:06AM |
Re: web control with RepRap Firmware Version 1.09 May 06, 2015 07:30AM |
Re: web control with RepRap Firmware Version 1.09 May 06, 2015 12:36PM |
auser
xiandhq
... but when I write name of my machine(MyRepRapProormerod2001) in the browser address bar nothing happened.
I guess this is too long, try "MyRepRapProorme" as ZPL suggested above (or maybe try MyRepRapProormer (15 / 16 charachters))
Re: web control with RepRap Firmware Version 1.09 May 07, 2015 05:57AM |
zombiepantslol
auser
xiandhq
Yes indeed, the NetBIOS name is limited to 15 chars (+ terminating zero) in the firmware. Connecting to [MyRepRapProorme] should work on a Windows machine, however as Dave already pointed out, it might be necessary to enable NetBIOS in the TCP/IP settings first. The same name is used in the DHCP request, so you may have a chance that it is resolved by your router's DNS server as well.
