Re: New experimental firmware 1.09a-dc42 June 04, 2015 03:17PM |
Re: New experimental firmware 1.09a-dc42 June 04, 2015 04:47PM |
appjaws1
David,
Today I loaded your firmware 1.09a and I just had to let you know how pleased I am with the new move code, the machine seems to be running a lot smoother and the quality of the prints are better.
Re: New experimental firmware 1.09a-dc42 June 04, 2015 05:20PM |
Re: New experimental firmware 1.09a-dc42 June 07, 2015 03:37AM |
Re: New experimental firmware 1.09a-dc42 June 07, 2015 04:42AM |
Re: New experimental firmware 1.09a-dc42 June 07, 2015 04:56PM |
Re: New experimental firmware 1.09a-dc42 June 07, 2015 07:03PM |
>>>M574 Z1 S1 SENDING:M574 Z1 S1 >>>M574 SENDING:M574 Endstop configuration: X none , Y high end (active high) , Z low end (active high) >>>M119 SENDING:M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped
Re: New experimental firmware 1.09a-dc42 June 08, 2015 04:01AM |
Re: New experimental firmware 1.09a-dc42 June 10, 2015 11:06AM |
Re: New experimental firmware 1.09a-dc42 June 11, 2015 12:00PM |
Re: New experimental firmware 1.09a-dc42 June 11, 2015 12:13PM |
Firefox3D
Think I know the answer to this, but is there any firmware limit to the Z axis maximum? I am asking as I was looking at rebuilding my Ormerod to print up to around 400mm on the Z axis
Re: New experimental firmware 1.09a-dc42 June 11, 2015 12:49PM |
Re: New experimental firmware 1.09a-dc42 June 11, 2015 12:52PM |
Re: New experimental firmware 1.09a-dc42 June 11, 2015 02:00PM |
Firefox3D
Re: New experimental firmware 1.09a-dc42 June 11, 2015 03:17PM |
dc42
Firefox3D
You can set Z axis minima and maxima using M208, but the firmware does not currently enforce them. Maybe it should?
Re: New experimental firmware 1.09a-dc42 June 12, 2015 09:08AM |
dc42
Firefox3D
Re: New experimental firmware 1.09a-dc42 June 12, 2015 11:15AM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 12:41PM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 12:57PM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 01:39PM |
Firefox3D
Hi Dario,
What differences are you seeing in print quality?
Also out of interest does Simplify3D give better quality?
Thanks
Jon
Re: New experimental firmware 1.09a-dc42 June 12, 2015 01:43PM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 01:52PM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 02:03PM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 02:18PM |
Firefox3D
Really?
Must be some kind of bottleneck in the software processing for it to take that long. I have loaded some fairly complex models and slicing has taken no more than a minute with support structure. Do you have any idea how many triangles are in the file that makes the STL or OBJ?
Re: New experimental firmware 1.09a-dc42 June 12, 2015 02:21PM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 02:27PM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 02:35PM |
Darathy
same ,i have never had a slice take more then 2min with slic3r 1.2.7
Re: New experimental firmware 1.09a-dc42 June 12, 2015 03:02PM |
Firefox3D
I'm not saying the support structure is perfect and haven't tried Simplify3D, I was just trying to understand how complex the model was for it to take 2 days to process, what PC processor are you using, I have an older dual core overclocked equivalent to around a 3.2Ghz intel i3
I have used Slic3r 1.1.7, 1.2.7 and have just downloaded 1.2.8, don't think they have changed anything to do with support structure recently though.
The picture of the Z support in black does look very good, is that with the earlier firmware and do you have a pic of what it looks like with 1.09a or any other comparison pics of print quality vs 0.78?
Re: New experimental firmware 1.09a-dc42 June 12, 2015 03:09PM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 03:28PM |
Ormerod187
Hi dc42,
too many quality problems ... back to previous It seems much better.
