Printing axis Calibration 90 ABS problem on Z June 11, 2015 12:36PM |
# generated by Slic3r 1.2.8 on Thu Jun 11 17:51:08 2015 avoid_crossing_perimeters = 1 bed_shape = 0x0,200x0,200x200,0x200 bed_temperature = 110 before_layer_gcode = bottom_solid_layers = 3 bridge_acceleration = 0 bridge_fan_speed = 100 bridge_flow_ratio = 1 bridge_speed = 15 brim_width = 0 complete_objects = 0 cooling = 0 default_acceleration = 0 disable_fan_first_layers = 3 dont_support_bridges = 1 duplicate_distance = 6 end_gcode = G1 X2 Y190; park the machine\nM0; stop external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0 external_perimeter_speed = 70% external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extruder_offset = 0x0 extrusion_axis = E extrusion_multiplier = 0.833 extrusion_width = 0 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #FFFFFF filament_diameter = 1.75 fill_angle = 45 fill_density = 40% fill_pattern = rectilinear first_layer_acceleration = 0 first_layer_bed_temperature = 110 first_layer_extrusion_width = 0 first_layer_height = 0.3 first_layer_speed = 50% first_layer_temperature = 240 gap_fill_speed = 15 gcode_arcs = 0 gcode_comments = 0 gcode_flavor = reprap infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 60 interface_shells = 0 layer_gcode = layer_height = 0.2 max_fan_speed = 100 max_print_speed = 80 max_volumetric_speed = 0 min_fan_speed = 35 min_print_speed = 10 min_skirt_length = 10 notes = nozzle_diameter = 0.5 octoprint_apikey = octoprint_host = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].g overhangs = 1 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_speed = 60 perimeters = 2 post_process = pressure_advance = 0 raft_layers = 0 resolution = 0 retract_before_travel = 2 retract_layer_change = 1 retract_length = 5 retract_length_toolchange = 10 retract_lift = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 45 seam_position = random skirt_distance = 6 skirt_height = 1 skirts = 3 slowdown_below_layer_time = 0 small_perimeter_speed = 20 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 60 spiral_vase = 0 standby_temperature_delta = -5 start_gcode = G21 ; set units to millimeters\nM203 X6000 Y6000 Z500 E3000 ; Allow 100mm/s speeds\nG90 ; use absolute coordinates\nM83 ; use relative distances for extrusion\nG1 Z5 F200 ; lift nozzle\nG1 X2 Y50 F2000; Go to wait for warm position\nM140 S[first_layer_bed_temperature] ; Set bed heater\nM116 ; Wait for everything (Bed temp)\nT0; Select extruder\nM104 S[first_layer_temperature]\nM116; Wait for extruder temp as well support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_extruder = 1 support_material_interface_layers = 0 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = rectilinear support_material_spacing = 2.5 support_material_speed = 70 support_material_threshold = 0 temperature = 240 thin_walls = 1 threads = 5 toolchange_gcode = top_infill_extrusion_width = 0 top_solid_infill_speed = 70% top_solid_layers = 4 travel_speed = 150 use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 vibration_limit = 0 wipe = 0 xy_size_compensation = 0 z_offset = 0
; Ormerod 1 config file for dc42 Duet firmware M111 S0 ; Debug off M550 PZonzo 3D ; Machine name (can be anything you like) M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address M552 P192.168.0.14 ; IP address M554 P192.0.0.1 ; Gateway M553 P255.255.255.0 ; Netmask M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M574 X0 Y2 Z0 P1 ; set endstop configuration (Y endstop only, at high end, active high) M906 X800 Y1000 Z800 E800 ; Set motor currents (mA) M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 1 operating and standby temperatures M92 E420 ; Set extruder steps per mm (single nozzle) M558 P1 ; Use an unmodulated Z probe or an intelligent Z probe G31 Z0.35 P500 ; Set the probe height and threshold (put your own values here) ;*** If you have a Duet board with 4.7K thermistor series resistors, change R1000 to R4700 to the following M305 commands M305 P0 R1000 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 R1000 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 R1000 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the IR sensor M557 P0 X30 Y30 ; Four... M557 P1 X30 Y170 ; ...probe points... M557 P2 X170 Y170 ; ...for bed... M557 P3 X170 Y30 ; ...levelling M557 P4 X100 Y100 ; 5th probe point for levelling (un-comment this if you are using a dc42 differential IR probe) ;*** if you are using axis compensation, put the figures in the following command M556 S78 X0 Y0 Z0 ; Axis compensation here M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute M208 X214 Y204 ; set axis maxima (adjust to suit your machine) M208 X-4 Y0 S1 ; set axis minimum (adjust to make X=0 the edge of the bed)
Re: Printing axis Calibration 90 ABS problem on Z June 11, 2015 01:02PM |
Re: Printing axis Calibration 90 ABS problem on Z June 11, 2015 02:33PM |
Re: Printing axis Calibration 90 ABS problem on Z June 11, 2015 06:03PM |
Re: Printing axis Calibration 90 ABS problem on Z June 11, 2015 07:57PM |
Darathy
if it no trouble i would be interested to test it
Re: Printing axis Calibration 90 ABS problem on Z June 12, 2015 02:30AM |
Re: Printing axis Calibration 90 ABS problem on Z June 12, 2015 09:22AM |
Re: Printing axis Calibration 90 ABS problem on Z June 13, 2015 08:08AM |
Re: Printing axis Calibration 90 ABS problem on Z June 13, 2015 01:52PM |
Re: Printing axis Calibration 90 ABS problem on Z July 03, 2015 06:19AM |
Re: Printing axis Calibration 90 ABS problem on Z July 03, 2015 10:39AM |
Re: Printing axis Calibration 90 ABS problem on Z July 03, 2015 11:54AM |
Re: Printing axis Calibration 90 ABS problem on Z July 03, 2015 02:16PM |
Re: Printing axis Calibration 90 ABS problem on Z July 03, 2015 06:04PM |
Re: Printing axis Calibration 90 ABS problem on Z July 04, 2015 03:20AM |
Zonzo
...my first doubt was that something change on the termistor reading parameter
Ps, I've just update the firmware to 1.9c
Re: Printing axis Calibration 90 ABS problem on Z July 04, 2015 04:36AM |
Re: Printing axis Calibration 90 ABS problem on Z July 04, 2015 05:40AM |
Re: Printing axis Calibration 90 ABS problem on Z July 04, 2015 07:18AM |
Re: Printing axis Calibration 90 ABS problem on Z July 04, 2015 12:43PM |
Re: Printing axis Calibration 90 ABS problem on Z July 04, 2015 02:45PM |
Zonzo
..I agree that it is a temperature problem but I can't understand why the same hardware configuration have work well some month ago and give me problem now...
..(nobody have designed an airduct that use a bigger fan??)
Re: Printing axis Calibration 90 ABS problem on Z July 05, 2015 09:32AM |
Re: Printing axis Calibration 90 ABS problem on Z July 05, 2015 12:27PM |
Re: Printing axis Calibration 90 ABS problem on Z July 05, 2015 12:36PM |
Re: Printing axis Calibration 90 ABS problem on Z July 05, 2015 02:25PM |
Zonzo
...2- there is another way to make the axis compensation?
Re: Printing axis Calibration 90 ABS problem on Z July 05, 2015 03:42PM |
Re: Printing axis Calibration 90 ABS problem on Z July 07, 2015 03:20PM |
Re: Printing axis Calibration 90 ABS problem on Z July 08, 2015 01:35AM |
Re: Printing axis Calibration 90 ABS problem on Z July 08, 2015 02:58AM |
Zonzo
..I have print that cooling duct and I've think to attach the dc probe using a "L" printed support fixed to the hole of the original probe.... I'll check for that this evening..
Erik, cous You post your last gode please, i want to print that and see the difference
Re: Printing axis Calibration 90 ABS problem on Z July 08, 2015 01:49PM |
ormerod168
..will have to print your original sliced calibration_90mm.gcode again to see how much influence the skinny infill have..
Re: Printing axis Calibration 90 ABS problem on Z July 09, 2015 01:13AM |
