Re: Request for Simplify3D gcode test July 16, 2015 04:07PM |
Re: Request for Simplify3D gcode test July 16, 2015 04:08PM |
G91 G1 Z5 ;End (for object height detection) G90 G1 X0 Y200 F6000 ;M107 ;M0 M104 S0 ; turn off extruder M140 S0 ; turn off bed ;M84 ; disable motors
Re: Request for Simplify3D gcode test July 16, 2015 04:24PM |
Re: Request for Simplify3D gcode test July 16, 2015 04:31PM |
Re: Request for Simplify3D gcode test July 16, 2015 06:52PM |
Re: Request for Simplify3D gcode test July 16, 2015 07:35PM |
Re: Request for Simplify3D gcode test July 17, 2015 07:55AM |
bgkdavis
The settings that are giving the most grief are the speeds, it appears the S3D pritnts a LOT slower than Slic3r, but the speeds I see in the program don't make a great deal of sense when I compare them to the settings and the settings in Slic3r... of course this could just be pointing out that my actual problem with slic3r was it was printing too fast
Re: Request for Simplify3D gcode test July 17, 2015 08:07AM |
dmould
bgkdavis
S3D speed settings are in mm per minute rather than mm per second, so you need to multiply your Slic3r settings by 60.
Dave
Re: Request for Simplify3D gcode test July 17, 2015 08:19AM |
Re: Request for Simplify3D gcode test July 17, 2015 09:13AM |
ormerod168
Firefox3D
G1 X0 Y200 F6000
I like to park the machine at G1 X205 Y205 after the print, to clean the nozzle (you retract 10mm and suppose its clean but its not, its snot) before it cools down and clear the bed area for cleaning before the next print
Erik
Re: Request for Simplify3D gcode test July 17, 2015 09:17AM |
Re: Request for Simplify3D gcode test July 17, 2015 09:44AM |
Treito
ormerod168
Firefox3D
...being extremely picky - tiny bit of stringing between the really small V cuts at the top, but that's ok as it's a very quick needle file removal...
..reducing the minimal travel distance before retraction might make a difference
[attachment 58181 SF3D_retraction.JPG]
Erik
Thanks for this advice. I just changed this in my settings. What about your speed settings? (Others tab)
Re: Request for Simplify3D gcode test July 17, 2015 09:52AM |
Re: Request for Simplify3D gcode test July 17, 2015 02:49PM |
Re: Request for Simplify3D gcode test July 17, 2015 05:55PM |
Re: Request for Simplify3D gcode test July 18, 2015 02:50AM |
Darathy
how do you force a T0 command before the temperature is set? in slic3r i could just put T0 attop to custom start code and it would put it at the start of the file ,but Simplify puts it like
G90
M83
M106 S0
M140 S65
M190 S65
M104 S190 T0
M109 S190 T0
T0
slic3r:
M107
M190 S60 ; set bed temperature
M104 S190 ; set temperature
T0
G28 Z0 f3000
M83
M109 S190 ; wait for temperature to be reached
How do i make S3D to put T0 before M109 command??
Re: Request for Simplify3D gcode test July 18, 2015 03:00AM |
Re: Request for Simplify3D gcode test July 18, 2015 03:06AM |
Re: Request for Simplify3D gcode test July 18, 2015 03:15AM |
bgkdavis
I spent some more time with S3Ds settings for my MEndel 3 tri colour and have some success'
When using Slic3er I was having some serious ooze problems, that was leading me to doubt the wisdom of a tri extruder printer
Re: Request for Simplify3D gcode test July 18, 2015 03:24AM |
Re: Request for Simplify3D gcode test July 18, 2015 04:46AM |
Re: Request for Simplify3D gcode test July 18, 2015 06:57AM |
dougal1957
Looks to me like it has implied T0 on the M104/M109 lines in Simplify3D which I guess is absolutely fine you could also put the T0 in your Config.g file.
I to have taken the plunge and purchased S3D And boy is it a lot quicker than Slic3r will generate some test prints with it later and see how much difference it makes to the Quality of the Prints.
Doug
Re: Request for Simplify3D gcode test July 18, 2015 07:49AM |
Re: Request for Simplify3D gcode test July 18, 2015 12:43PM |
dc42
It occurs to me that when the firmware sees M109 T0, it probably makes sense for the firmware to execute T0 implicitly. You wouldn't ask to "set temperature of tool 0 and wait till it is reached" unless you intended the tool to be selected.
Re: Request for Simplify3D gcode test July 19, 2015 08:49AM |
Darathy
dc42
If i understand you correctly. you mean firmware should see M109 T0 and turn on the hot end. But it does not see it and starts printing withought actualy extruding). It has to be seporate from the M109 command and has to come 1st in Gcode line.
Re: Request for Simplify3D gcode test July 19, 2015 09:07AM |
dougal1957
Darathy
dc42
I can now confirm this action I have got arround it by putting a T0 command at the end of the Config.g File this however won't let you put the G28 in the Start code either
Re: Request for Simplify3D gcode test July 19, 2015 09:14AM |
dougal1957
Darathy
dc42
Re: Request for Simplify3D gcode test July 19, 2015 09:28AM |
dc42
dougal1957
Darathy
dc42
Why can't you put a G28 in the start gcode? Not that I want to, I'm just curious.
Re: Request for Simplify3D gcode test July 19, 2015 09:33AM |
dougal1957
another problem has just reared it's ugly head tho and not sure what is causing it?
When i heat the hotend to 230+ the temp's error out until I reset the DUET if I keep it to 225 or less then it is fine just wondering if I have an Iffy Thermistor?
Any suggestion's re this would be gratefully received
Re: Request for Simplify3D gcode test July 19, 2015 09:34AM |
