Re: Request for Simplify3D gcode test July 19, 2015 10:19AM |
dc42
dougal1957
another problem has just reared it's ugly head tho and not sure what is causing it?
When i heat the hotend to 230+ the temp's error out until I reset the DUET if I keep it to 225 or less then it is fine just wondering if I have an Iffy Thermistor?
Any suggestion's re this would be gratefully received
Probably the time-to-hot timer is timing out. See [reprap.org]. I think the default is 120 seconds.
Re: Request for Simplify3D gcode test July 19, 2015 11:21AM |
Re: Request for Simplify3D gcode test July 19, 2015 11:35AM |
G1 E-10 F2400 G91 G1 Z5 F360 G90 G1 X0 Y0 F6000 M107 M0
Re: Request for Simplify3D gcode test July 19, 2015 02:52PM |
Re: Request for Simplify3D gcode test August 01, 2015 05:00PM |
dougal1957
dc42
dougal1957
Yep reckon that could be it trouble with a 25 watt element I suppose may think about swapping it out for a 40 watt one.
Doug.
And yes Darathy always on heat up never on print's.
I know I am posting in the Ormerod section but my Printer is a large Delta using the Duet and both myself and Dave were getting random blobbing using the E3D Hotend's and Slic3r (Mine is 1.2.9) and this has totally disappeared with S3D so for me it was worth the $149 (and the speed improvement as well).
Re: Request for Simplify3D gcode test August 01, 2015 09:28PM |
Re: Request for Simplify3D gcode test August 02, 2015 04:40AM |
Re: Request for Simplify3D gcode test August 02, 2015 04:43AM |
Re: Request for Simplify3D gcode test August 02, 2015 04:45AM |
Re: Request for Simplify3D gcode test August 02, 2015 04:57AM |
Re: Request for Simplify3D gcode test August 02, 2015 05:05AM |
Re: Request for Simplify3D gcode test August 02, 2015 05:08AM |
Re: Request for Simplify3D gcode test August 02, 2015 05:10AM |
Re: Request for Simplify3D gcode test August 02, 2015 06:12AM |
Re: Request for Simplify3D gcode test August 02, 2015 07:59AM |
Re: Request for Simplify3D gcode test August 02, 2015 12:05PM |
Re: Request for Simplify3D gcode test August 02, 2015 02:07PM |
Re: Request for Simplify3D gcode test August 02, 2015 02:09PM |
Re: Request for Simplify3D gcode test August 02, 2015 02:17PM |
Re: Request for Simplify3D gcode test August 02, 2015 02:50PM |
Re: Request for Simplify3D gcode test August 02, 2015 03:10PM |
Re: Request for Simplify3D gcode test August 02, 2015 03:20PM |
Re: Request for Simplify3D gcode test August 02, 2015 03:29PM |
Re: Request for Simplify3D gcode test August 02, 2015 03:36PM |
Re: Request for Simplify3D gcode test August 02, 2015 03:41PM |
Re: Request for Simplify3D gcode test August 02, 2015 04:36PM |
Darathy
i'm using [3dfilaments.ie] for evrything atm ,since i have like 5 spools of it. I will try some Esun which i have 1 spool of it left and see if it has blobs aswell. but thisone has bad layer adhesion and breaks easy.
Re: Request for Simplify3D gcode test August 02, 2015 05:02PM |
Re: Request for Simplify3D gcode test August 02, 2015 05:25PM |
Re: Request for Simplify3D gcode test August 02, 2015 05:43PM |
Re: Request for Simplify3D gcode test August 03, 2015 12:37AM |
