Which design software December 24, 2015 10:40AM |
Re: Which design software December 24, 2015 10:47AM |
Jon Steward
Hi
I've made a few basic enclosures and covers also cylindrical objects with openscad.
I'd like to move on to a package which requires less coding to write and simpler to use.
Any recommendations?
Jon
Re: Which design software December 24, 2015 10:48AM |
Re: Which design software December 24, 2015 12:51PM |
Re: Which design software December 24, 2015 08:39PM |
dougal1957
FreeCad is pretty good but takes a little work to learn.
Re: Which design software December 25, 2015 01:10AM |
Re: Which design software December 25, 2015 03:14AM |
Re: Which design software January 01, 2016 06:45AM |
Treito
OpenSCAD needs in this case a .dxf-file which has be drawn by another program so you need alt least two programs and with FreeCAD you only need one.Quote
dougal1957
Re: Which design software January 01, 2016 07:39AM |
Re: Which design software January 01, 2016 09:38AM |
Re: Which design software January 01, 2016 09:59AM |
Re: Which design software January 04, 2016 10:34AM |
Treito
Like I said there are many designs on thingiverse which are based on a .DXF. And how else would you do a complicated sketch as basis?
Re: Which design software January 04, 2016 01:45PM |
Re: Which design software January 04, 2016 02:55PM |
Re: Which design software January 04, 2016 03:31PM |
Jon Steward
Hi
Jon
Re: Which design software January 05, 2016 04:40AM |
Re: Which design software January 05, 2016 06:57AM |
Re: Which design software January 05, 2016 07:50AM |
Treito
I need the visual feedback when designing a complicated shape like the X-arm for example. I would draw the sketch with a CAD program to do the extrusion later with OpenSCAD. Drawing regularly shapes like gears, vases or pulleys for example is done the most effective using OpenSCAD, but for all other items? Could you draw an 3D-printer completely in OpenSCAD?
Re: Which design software January 05, 2016 09:33AM |
Treito
The big disadvantage in my eyes is the assembling. There is no way using DesignSpark to place one part in accordance to another part. It is always freely moveable. As I want to design a complete printer soon it is not useable for me.
Re: Which design software January 05, 2016 11:40AM |
fotomas
Some very useful Keyboard shortcuts that are good to know from the beginning:
In 3D mode:
Click flat surface you want to draw on, press, K, V, Z
This will start 2D sketch mode (K)
Straiten the sketch surface (V)
And zoom to selected area (Z)
The sketch away....
Back to 3D mode with D
Middle mouse button rotates, middle + shift pans.
Explore how the axis thingy in the drawing areas bottom left corner works, it is very useful.
I will happily answer any questions on how to create things.
Re: Which design software January 05, 2016 01:34PM |
fotomas
Parts can be placed at exact measurements relative to each other, in free space.
Like this:
[attachment 69003 OrmDS_1.PNG]
Re: Which design software January 05, 2016 01:54PM |
Treito
fotomas
Like this:
That is right, but what happens if you move the extrusion for example? You would have to adjust the feet. Or if I would like to add a part I do not have to care about the coordinates so it fits. I just say align this side to that side or this whole axis with that one and so one.
Re: Which design software January 05, 2016 02:45PM |
Re: Which design software January 06, 2016 08:25AM |
