Fix your clips! December 05, 2018 03:50AM |
Re: Fix your clips! December 05, 2018 04:00AM |
Re: Fix your clips! December 05, 2018 04:24AM |
Re: Fix your clips! December 05, 2018 05:00AM |
WesBrooks
I'm putting off printing a new extruder for the time being as I would like to have a more detailed look at the belt extruder designs. However, that maybe forced on me early if this clip doesn't hold. If so I'll be looking for something very standard, just with a boss for a bowden connector with PTFE guide if needed.
There are herringbone gears (constant contact and no axial force that you would get with a plain helical gear) for the z-axis on thingverse. Search Ormerod and you will find masses of tuning options available.
My current drive on accuracy is in an effort to print the herringbone gear versions of the extruder gears.
