New to 3d printing with smartrap need some help June 05, 2014 10:53PM |
Re: New to 3d printing with smartrap need some help June 05, 2014 11:03PM |
duranza
Hello all,
I have built the version 4.7 and have everything set up, but I'm having trouble extruding. I'm using this hot end with no luck hot end i'm using. Any help is apreciated.
Thanks,
Jonathan
Re: New to 3d printing with smartrap need some help June 05, 2014 11:20PM |
Re: New to 3d printing with smartrap need some help June 05, 2014 11:37PM |
duranza
I'm using an mk7 gear and a direct drive extruder like it calls out for. I have tried running from 180 to 210 with no difference. And you are right about the jamming. I have to clean it with a drill bit and jams if I stop printing. If you can call it printing. I have not been able to print anything but blobs. So it is safe to say that I need a J-head style one then?
Anonymous User
Re: New to 3d printing with smartrap need some help June 05, 2014 11:39PM |
Re: New to 3d printing with smartrap need some help June 05, 2014 11:50PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 12:03AM |
Re: New to 3d printing with smartrap need some help June 06, 2014 12:09AM |
Re: New to 3d printing with smartrap need some help June 06, 2014 12:11AM |
goldenmongoose
I've seen this hot end for sale and it seemed to good to be true. I guess it is. I think it's important that it's both cheap and works.
Anonymous User
Re: New to 3d printing with smartrap need some help June 06, 2014 12:44AM |
Re: New to 3d printing with smartrap need some help June 06, 2014 12:47AM |
duranza
It is too good to be true. Do not buy. Unless you can use for the parts. Regpye, I am a cnc machinist, so I can make my own parts. I also have access to an electronics surplus store that has fans and heatsinks and stuff. I just wish I had the experience with this stuff, but I guess if you don't stumble you don't learn...
Re: New to 3d printing with smartrap need some help June 06, 2014 12:55AM |
goldenmongoose
regpye, cudos on the new hot end design. I wasn't refering to the performance of your hot end. But, it's easy to make an expensive hot end that works well with PLA. It's much harder to make an inexpensive hot end that works well with PLA. I saw you're hot end design and it looks cool. But, are there any source files available? I'm curious because it looks pretty long compared to most others. A standard J-head is about 2.5" and reg's is 4"?
Re: New to 3d printing with smartrap need some help June 06, 2014 01:49AM |
goldenmongoose
Anonymous User
Re: New to 3d printing with smartrap need some help June 06, 2014 02:13AM |
Re: New to 3d printing with smartrap need some help June 06, 2014 08:59AM |
Re: New to 3d printing with smartrap need some help June 06, 2014 12:48PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 01:29PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 03:56PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 04:48PM |
madmike8
Oh, if you move things over to the Jhead-Lite you'll also need This ($1.50), Sorry... or some form of heat sink...
Re: New to 3d printing with smartrap need some help June 06, 2014 05:49PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 09:14PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 09:45PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 09:55PM |
duranza
Ok, so I made this heat sink to use with the parts and I still get jamming. I can push the filament forcefully and it will extrude, but the stepper just kicks back. I'm just going to buy the j-head light and be done with it. I tryed to put the temperature to 230 but no help. just makes bubbling sounds.
Re: New to 3d printing with smartrap need some help June 06, 2014 10:16PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 10:22PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 10:48PM |
duranza
The stepper is set up at 900ma of current and it sounds great feeding through the tube, but as soon as it reaches the tip it extrudes a bit and then it stops and jams. Could it be that is trying to extrude too fast? I calibrated it by using the lcd menu and extruding 1mm and measuring and adjusting. Is there a better way? Before trying to run with the new heatsink, I cleared the stainless 6mm threaded rod and heated up the tip until I could see through the .4 mm hole. This is so frustrating.
Re: New to 3d printing with smartrap need some help June 06, 2014 10:56PM |
duranza
This is what my build looks like. Everything went smooth with the assembly.
Re: New to 3d printing with smartrap need some help June 06, 2014 11:26PM |
Re: New to 3d printing with smartrap need some help June 06, 2014 11:52PM |
Re: New to 3d printing with smartrap need some help June 07, 2014 12:04AM |
duranza
Ok. I have confirmed the steps per mm to be good. It is set in marlin at 91.23 steps per mm and it is right on. I did try to run at 20% feed rate and got some progress. It extruded some steady strands for about a minute then it started clicking/skipping steps again. I have verified that the temperature is within 1 degree of what it displays on the screen. I did also free up the bowden tube to let it be by itself.
