Re: Djinn5150's SmartRap Core Build April 06, 2015 11:18AM |
Re: Djinn5150's SmartRap Core Build April 08, 2015 10:39PM |
Re: Djinn5150's SmartRap Core Build April 08, 2015 11:00PM |
Re: Djinn5150's SmartRap Core Build April 09, 2015 10:46AM |
Re: Djinn5150's SmartRap Core Build April 09, 2015 01:18PM |
rcjoseb
I was thinking of duplicating the Z axis assembly and placing one in the front edge of the print bed to fully support it. Both Z motors would then run at the same time, hopefully, off of one stepper on the RAMPS board. That would ruin access from the front but I could cut a door on one of the sides to overcome that.
Re: Djinn5150's SmartRap Core Build April 09, 2015 02:04PM |
Thanks for the compliment...like I said its not exactly my design but did do some changes.Quote
rcjoseb
That hot end works great so far. As a test, I tried printing a small part at 80ms with a 90ms feed rate for PLA and it came out pretty good. Just some minor defects. I normally print at 20ms, slow but parts come out beautiful.
Nice work on the beefed up Z axis parts. How are you attaching the M8 threaded rod to the motor shaft being that the diameters are different?
Re: Djinn5150's SmartRap Core Build April 09, 2015 04:13PM |
Re: Djinn5150's SmartRap Core Build April 09, 2015 04:15PM |
Re: Djinn5150's SmartRap Core Build April 10, 2015 10:37AM |
Re: Djinn5150's SmartRap Core Build April 10, 2015 01:37PM |
Re: Djinn5150's SmartRap Core Build April 10, 2015 02:56PM |
Re: Djinn5150's SmartRap Core Build April 10, 2015 08:44PM |
Re: Djinn5150's SmartRap Core Build April 10, 2015 11:41PM |
Re: Djinn5150's SmartRap Core Build April 14, 2015 07:46PM |
Re: Djinn5150's SmartRap Core Build April 14, 2015 08:08PM |
Re: Djinn5150's SmartRap Core Build April 14, 2015 08:16PM |
Re: Djinn5150's SmartRap Core Build April 14, 2015 10:25PM |
Re: Djinn5150's SmartRap Core Build April 14, 2015 10:26PM |
Re: Djinn5150's SmartRap Core Build April 14, 2015 10:57PM |
rcjoseb
I found this modified extruder for the SmartRapCore in Thingiverse listed under SmartRap. I don't know if it works but looks like it will, especially with the added nut holes.
[www.thingiverse.com]
Re: Djinn5150's SmartRap Core Build April 15, 2015 12:24AM |
Re: Djinn5150's SmartRap Core Build April 21, 2015 03:03PM |
Re: Djinn5150's SmartRap Core Build April 23, 2015 03:32PM |
djinn5150
Mike, where did you source your belt? I am guessing here but from what i can find on ebay the closed loops are measured by teeth count? McMaster doesnt have gt2 from what i can tell but I will try to mock something up later today, mine is so wide its gonna take one long belt, thinking skate bearings for "idlers", Might have to go with printed pulley's on the 8mm rods if we can't find 8mm shaft pulley's easily enough. Ok, enough hijacking rc's thread...I will continue this on my build lol
Re: Djinn5150's SmartRap Core Build April 24, 2015 06:33AM |
Re: Djinn5150's SmartRap Core Build April 24, 2015 12:08PM |
willera
Did you guys use the standard firmware for Marlin on [github.com] ?
what did you have to change in the congif files?
EDIT: just realised that its actually this...[github.com]
Re: Djinn5150's SmartRap Core Build April 24, 2015 02:24PM |
Re: Djinn5150's SmartRap Core Build May 02, 2015 01:49PM |
Re: Djinn5150's SmartRap Core Build May 02, 2015 02:09PM |
eviltoy
A question on the heavy duty carriage. Wouldn't the nut work its way out eventually like on the prusa i3? Maybe add a hole for a m3 screw to fix the nut in place permanently
Re: Djinn5150's SmartRap Core Build May 02, 2015 02:16PM |
Re: Djinn5150's SmartRap Core Build May 02, 2015 02:19PM |
Re: Djinn5150's SmartRap Core Build May 02, 2015 02:24PM |
