Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 12:30PM |
In file included from sketch/base.h:78:0, from /Users/karnhack/Desktop/MK4duo/MK4duo.ino:235: sketch/src/sanitycheck.h:538:8: error: #error "DELTA requires ABL_GRID_POINTS_X and ABL_GRID_POINTS_Y to be odd numbers." #error "DELTA requires ABL_GRID_POINTS_X and ABL_GRID_POINTS_Y to be odd numbers." ^ exit status 1 Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 12:51PM |
#error "DELTA requires ABL_GRID_POINTS_X and ABL_GRID_POINTS_Y to be odd numbers."Cioè la grigia deve avere un valore dispari... Tu hai messo 20 o metti 21 o metti 19...
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 01:20PM |
Lo sketch usa 144.644 byte (56%) dello spazio disponibile per i programmi. Il massimo è 253.952 byte. Le variabili globali usano 7.661 byte (93%) di memoria dinamica, lasciando altri 531 byte liberi per le variabili locali. Il massimo è 8.192 byte. Poca memoria disponibile, potrebbero presentarsi problemi di stabilità
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 01:30PM |
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 01:31PM |
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 01:32PM |
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 01:44PM |
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 01:57PM |
>>> M119 SENDING:M119 Reporting endstop status x_max: NOT TRIGGERED y_max: NOT TRIGGERED z_max: NOT TRIGGERED z_probe: TRIGGERED
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 02:17PM |
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 02:24PM |
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 02:41PM |
Re: Problema con BLTouch e MK4duo Rev 4.3.06 January 12, 2017 03:02PM |
