Re: Atfer Hbot, go to CoreXY. April 18, 2014 04:04AM |
Re: Atfer Hbot, go to CoreXY. April 18, 2014 04:33AM |
Re: Atfer Hbot, go to CoreXY. April 18, 2014 04:37AM |
Re: Atfer Hbot, go to CoreXY. April 18, 2014 05:15AM |
Re: Atfer Hbot, go to CoreXY. April 18, 2014 09:45AM |
Re: Atfer Hbot, go to CoreXY. April 18, 2014 12:01PM |
Re: Atfer Hbot, go to CoreXY. April 18, 2014 12:24PM |
Re: Atfer Hbot, go to CoreXY. April 18, 2014 12:32PM |
Re: Atfer Hbot, go to CoreXY. April 19, 2014 03:37AM |
Re: Atfer Hbot, go to CoreXY. April 20, 2014 07:17AM |
Re: Atfer Hbot, go to CoreXY. May 07, 2014 05:28PM |
Re: Atfer Hbot, go to CoreXY. May 07, 2014 07:16PM |
Re: Atfer Hbot, go to CoreXY. May 07, 2014 08:37PM |
Re: Atfer Hbot, go to CoreXY. May 08, 2014 01:04AM |
Re: Atfer Hbot, go to CoreXY. May 08, 2014 02:36AM |
Re: Atfer Hbot, go to CoreXY. May 08, 2014 02:39PM |
Re: Atfer Hbot, go to CoreXY. May 08, 2014 03:06PM |
Re: Atfer Hbot, go to CoreXY. May 08, 2014 05:55PM |
Re: Atfer Hbot, go to CoreXY. May 10, 2014 10:26AM |
Re: Atfer Hbot, go to CoreXY. May 10, 2014 11:17AM |
Reinhold
Hi Jan
Would you mind explaining/confirming some details of your heated table?
(it seems reality is "at least in part" unlike drawing )
You are correct. In my model the sandwich of the printbed is on top of the extrusions. In real hardware the extrusions are in between the two alu plates.
0) Table size x mm x y mm (220x220) ?
The table size is 220 x 200 mm. I ordered the alu plates together with the extrusions at motedis. You can order plates there upto 200 mm wide. I would have prefered 220x220
1) (Borosilicate ?) Glass plate thickness h1 (3 mm) ?
I use normal window glass. This is perfectly OK if you have a good heat spreader like the alu plate used here.
2) Aluminium plate thickness h2 mm (6 mm)?
Yes 6 mm. This is probably overkill. I think 4 mm is OK, maybe even 3 mm. Reason mentioned above
3) What sort of heater are you using? (4 different cable types confuse me ;-) )
I use 4 power resistors of 4.7 ohm, the 50W type. These are all in parallel (2 by 2 and connected together in the terminal block), so gives 1.2 ohm Which makes 122.6 W at 12V.
4) The gap between Extrusion and upper Aluminum plate is because...?
To level the bed.
5) "?" you have 3 (4?) springs with M5 screws to adjust table height?
I have three M4 screws with springs to level the bed. Two at the back in the corners and one in the front center.
A screw enters at top top alu plate and is secured with a nut at the back. A spring is slided over the screw and rests on the bottom alu plate. At the back of the bottom alu plate is a thumb-nut. These twree thumb-nuts are used to level the bed.
6) Any special insulation used ?
Nothing special just rockwool.
7) Aluminium plate thickness h3 mm (6 mm)?
6 mm same as above
8) Do you print on the naked Glass plate
Yes, for ABS I use haispray. Apply hairspray, let it dry and then spread it with a paper towel wetted with spiritus.
For nylon I use woolglue. Just a few drops and spread it with a wet paper towel.
9) at which temperature (with PLA, Nylon, ABS) ?
110 deg for ABS and room temperature for nylon.
10) ... how is the plate fixed to the extrusions... ;-)
Just 4 m4 screws through the lower alu plate
(lot's of screws through the top aluminum plate...but)
These are for the power resistors.
How do you adjust the table height for a print anyway?
Using the Z-endstop
BOM: (^_*)
Yes, I know, I have to work on that.
2 x Aluminum plate 220x220x 6mm
1 x Borosilicate plate 220x220x 3mm
Heater...
Temp Sensor...
Insulation ...
Springs...
screws M5 ...M4
P.S.:
The layer height for the squirrel print was 0.1mm ?
0.2 mm layer, 0.35 nozzle
Those cool running Wantai motors are 42BYGHW609 (1.8°,1.7A,4000gcm,40mm) ?
More on that later.
P.P.S.: THANKS
Re: Atfer Hbot, go to CoreXY. May 10, 2014 01:21PM |
Re: Atfer Hbot, go to CoreXY. May 10, 2014 05:16PM |
Re: Atfer Hbot, go to CoreXY. May 10, 2014 06:26PM |
jand
BOM: (^_*)
Re: Atfer Hbot, go to CoreXY. May 10, 2014 06:36PM |
Re: Atfer Hbot, go to CoreXY. May 10, 2014 06:43PM |
Re: Atfer Hbot, go to CoreXY. May 10, 2014 06:58PM |
Re: Atfer Hbot, go to CoreXY. May 10, 2014 07:06PM |
Re: Atfer Hbot, go to CoreXY. May 11, 2014 06:58AM |
jand
The Z-axis is actually quite stable...
Re: Atfer Hbot, go to CoreXY. May 11, 2014 07:57AM |
Re: Atfer Hbot, go to CoreXY. May 11, 2014 09:58AM |
