Re: My coreXY design is progressing to the build stage December 17, 2016 08:00PM |
Re: My coreXY design is progressing to the build stage December 17, 2016 08:12PM |
Re: My coreXY design is progressing to the build stage December 19, 2016 11:05AM |
Re: My coreXY design is progressing to the build stage December 19, 2016 01:45PM |
Re: My coreXY design is progressing to the build stage December 22, 2016 07:09PM |
Re: My coreXY design is progressing to the build stage December 22, 2016 07:37PM |
Re: My coreXY design is progressing to the build stage December 22, 2016 08:24PM |
Re: My coreXY design is progressing to the build stage December 22, 2016 08:49PM |
Re: My coreXY design is progressing to the build stage December 22, 2016 09:04PM |
Re: My coreXY design is progressing to the build stage December 23, 2016 02:04AM |
Re: My coreXY design is progressing to the build stage December 23, 2016 06:31AM |
Re: My coreXY design is progressing to the build stage December 23, 2016 07:33AM |
Re: My coreXY design is progressing to the build stage December 23, 2016 07:55AM |
Mikk36
Because he's not using leadscrews at all?Quote
dc42
Why not just use finer pitch leadscrews?
Re: My coreXY design is progressing to the build stage December 23, 2016 08:30AM |
Re: My coreXY design is progressing to the build stage December 23, 2016 11:20AM |
dc42
DD, I saw our ad in Wanted for a worm drive. I doubt that you'll find one with a ratio of less than about 20:1, because the worm gear needs to engage with 2 or 3 teeth of the pulley, which requires using a pulley with sufficient teeth.
However, you may not need a worm gear. If the gear reduction is high enough, then the detent torque of the motor will be sufficient to prevent the bed falling. Unfortunately, many stepper motor manufacturers don't publish detent torque, but here is one that does: [motion.schneider-electric.com]. The long motor has a detent torque of 2.5Ncm. If you are using a 20 tooth pulley then it has a radius of 4/(2 * pi) cm so the belt force that the detent torque can resist is about 3.9N, which corresponds to a weight of about 0.39Kg. Therefore, a 5:1 gearbox would support a weight of just under 2Kg, and a 14:1 gearbox would support about 5kg. So a stepper motor with a planetary gearbox such as [www.omc-stepperonline.com] may be suitable - although unfortunately they don't publish the detent torque for that motor.
Another effect of using a gearbox is that the braking force you get if you short the motor coils rises with the square of the gear ratio.
HTH David
Re: My coreXY design is progressing to the build stage December 23, 2016 12:41PM |
Re: My coreXY design is progressing to the build stage December 23, 2016 01:13PM |
Re: My coreXY design is progressing to the build stage December 23, 2016 01:33PM |
the_digital_dentist
The biggest concern with other gear box types is backlash. Backlash wouldn't be a problem if the bed only moved one direction throughout a print, but if Z-lift on retraction is turned on, backlash could be a big problem. The more gears there are, the larger the backlash is likely to be, especially as it wears. I think the worm gear drive behaves more like a screw drive as gravity will keep the disc gear in contact with the worm gear at all times. Backlash shouldn't be a problem, even as it wears.
the_digital_dentist
The big question is how does belt drive compare to using screws? I'm using the belt to lift the bed on two sides, so comparison to two screws is most appropriate. Belt drive is pretty easy to build, and doesn't require a lot of mechanical precision. The worm gear drive is the most costly component. Using screws is a bit more complicated- the screws should be aligned parallel to the guide rails, bearings (thrust bearings on the bottom?) are required at each end of each screw, a closed loop belt with toothed pulleys for each screw add to cost. I suspect that when you add it all up the $ cost is about the same. Screws should provide more consistent layer thickness regardless of print height or mass (belts may stretch a bit as the print mass rises, resulting in thicker layers). Belts can't/won't create Z artifacts associated with bent screws (but could there be other artifacts associated with inconsistent tension or springiness?).
Re: My coreXY design is progressing to the build stage December 23, 2016 03:37PM |
Re: My coreXY design is progressing to the build stage December 24, 2016 08:59AM |
Re: My coreXY design is progressing to the build stage December 25, 2016 10:28PM |
dc42
HTH David
Re: My coreXY design is progressing to the build stage December 30, 2016 06:16PM |
Re: My coreXY design is progressing to the build stage December 30, 2016 11:22PM |
Re: My coreXY design is progressing to the build stage January 03, 2017 12:32PM |
Re: My coreXY design is progressing to the build stage January 03, 2017 12:44PM |
Re: My coreXY design is progressing to the build stage January 06, 2017 12:51PM |
Re: My coreXY design is progressing to the build stage January 07, 2017 04:34PM |
Re: My coreXY design is progressing to the build stage January 10, 2017 12:50AM |
Re: My coreXY design is progressing to the build stage January 10, 2017 06:31AM |
Re: My coreXY design is progressing to the build stage January 12, 2017 10:00PM |
