Re: My coreXY design is progressing to the build stage August 30, 2017 11:07AM |
I see.Quote
the_digital_dentist
No specific reason - I had some left-over pieces and didn't have any smaller stuff. Since there are no lateral forces on the bed smaller extrusion should work OK. I wasn't too worried about the weight- the Z axis drive I used can handle a LOT of weight.
Re: My coreXY design is progressing to the build stage August 30, 2017 11:20AM |
Re: My coreXY design is progressing to the build stage September 05, 2017 11:26PM |
Re: My coreXY design is progressing to the build stage September 13, 2017 04:22PM |
Re: My coreXY design is progressing to the build stage September 13, 2017 06:46PM |
Re: My coreXY design is progressing to the build stage September 14, 2017 02:26PM |
Re: My coreXY design is progressing to the build stage September 16, 2017 11:20AM |
Re: My coreXY design is progressing to the build stage September 16, 2017 11:52AM |
It looks like the Slic3r object has slightly better layer registration, but I can't imagine why the slicer would make any difference there.
Re: My coreXY design is progressing to the build stage September 16, 2017 12:37PM |
Re: My coreXY design is progressing to the build stage September 17, 2017 02:37PM |
Re: My coreXY design is progressing to the build stage September 18, 2017 07:12AM |
Re: My coreXY design is progressing to the build stage September 18, 2017 05:00PM |
Re: My coreXY design is progressing to the build stage September 18, 2017 07:20PM |
Re: My coreXY design is progressing to the build stage September 19, 2017 06:38AM |
Re: My coreXY design is progressing to the build stage September 19, 2017 08:26AM |
Re: My coreXY design is progressing to the build stage September 19, 2017 02:33PM |
Re: My coreXY design is progressing to the build stage September 19, 2017 04:39PM |
the_digital_dentist
In my case the acceleration is a pretty low 700 mm/sec^2 to avoid layer shifting due to the high moving mass of the Y axis. And it sounds like someone with thick thighs running a marathon in corduroy pants. Would the drivers on the Duet WiFI kill most of that noise, or is that noise created by the teeth of the belt slapping against the smooth pulley surfaces?
Re: My coreXY design is progressing to the build stage September 24, 2017 10:33PM |
Re: My coreXY design is progressing to the build stage September 26, 2017 10:58AM |
Shake it in a trunk, put it up, power "et voila". Indeed, when good engineering practice and proper assembly methods are used.|
Re: My coreXY design is progressing to the build stage September 26, 2017 03:17PM |
Re: My coreXY design is progressing to the build stage September 27, 2017 02:40AM |
Re: My coreXY design is progressing to the build stage September 27, 2017 04:59AM |
You can't convert one to a stepper motor, but you could convert one into a DC servo motor by attaching an incremental encoder. The encoder should be attached to the motor itself and not the gearbox output in order to reduce backlash.Quote
o_lampe
Just asked myself, if it would be possible to adapt a windscreen wiper wormdrive to a Stepper or a smaller wormdrive from electric window screens? This is the RepRap forum at least
Re: My coreXY design is progressing to the build stage September 27, 2017 07:11AM |
Re: My coreXY design is progressing to the build stage September 28, 2017 01:56AM |
Re: My coreXY design is progressing to the build stage September 29, 2017 07:58PM |
Re: My coreXY design is progressing to the build stage September 30, 2017 10:52AM |
o_lampe
It would be nice to find a wormgear that already requires a 5mm or 1/4" shaft diameter. Easier to adapt to common steppers...
Re: My coreXY design is progressing to the build stage October 05, 2017 11:16AM |
the_digital_dentist
You still need bearings, a mount, a motor, and means to couple to the shaft at the input and an output shaft. How many hours and what additional cost is there compared to just spending a few more $ and getting a Rino? That's why my development of the device using garage door gears stopped. OTOH, a low cost stepper driven worm gear would be useful for all sorts of things besides 3D printers.
Re: My coreXY design is progressing to the build stage October 17, 2017 12:47AM |
Re: My coreXY design is progressing to the build stage October 31, 2017 02:07PM |
Re: My coreXY design is progressing to the build stage October 31, 2017 02:25PM |
