Re: CoreXYNZ build September 12, 2016 11:10PM |
Re: CoreXYNZ build September 13, 2016 05:11AM |
Re: CoreXYNZ build September 14, 2016 12:52PM |
Re: CoreXYNZ build September 14, 2016 03:42PM |
Re: CoreXYNZ build September 15, 2016 10:46AM |
Re: CoreXYNZ build September 21, 2016 02:03AM |
Re: CoreXYNZ build September 21, 2016 03:04AM |
Re: CoreXYNZ build September 21, 2016 11:22AM |
Re: CoreXYNZ build September 21, 2016 06:02PM |
Re: CoreXYNZ build September 27, 2016 01:43AM |
Re: CoreXYNZ build September 28, 2016 01:51AM |
Re: CoreXYNZ build September 28, 2016 02:39PM |
Re: CoreXYNZ build October 22, 2016 09:49PM |
Re: CoreXYNZ build October 23, 2016 06:30AM |
RodF
Hard to say if it has retained flatness but I am able to adjust it if necessary.
Re: CoreXYNZ build October 23, 2016 07:06AM |
Calvinx66
RodF
I have a question about that, why the attempt at such flatness and accuracy when it was always going to moved, wouldn't it have been better to have built it on the normal work surface and do all final leveling once the unit it in its final location ?
Re: CoreXYNZ build October 23, 2016 08:52AM |
Re: CoreXYNZ build October 24, 2016 12:36AM |
Re: CoreXYNZ build October 24, 2016 06:16AM |
Re: CoreXYNZ build October 24, 2016 08:01AM |
Re: CoreXYNZ build October 24, 2016 08:10AM |
Re: CoreXYNZ build October 24, 2016 05:12PM |
Re: CoreXYNZ build October 26, 2016 06:57AM |
the_digital_dentist
I recently started rehabilitating a 3DS CubeX Duo printer. The cable chain that connects to the extruder carriage is one of it's nicer features. Instead of the traditional approach as you have taken it turns the cable chain 90 degrees and attaches it at the back of the frame. That makes for a large, graceful loop that won't cause a lot of wire flexing and allows shorter wires because they don't all have to run through both X and Y axis chains. 3DS actually ran the filament guide tubes through that loop which is probably why they laid it out that way- you can't bend the filament tubes too much or the extruders wouldn't be able to pull the filament through them. You can see what it looks like here:
There is a very small cable chain running along the Y axis to carry the X axis motor and end stop leads.
I removed the filament guide tube completely because one of the most common complaints about these machines was brittle PLA breaking inside the tubes. I'll be feeding filament from above making it much easier for the extruders to pull it and much less chance of even brittle filament breaking.
Re: CoreXYNZ build October 26, 2016 07:47AM |
Re: CoreXYNZ build October 27, 2016 05:48PM |
Re: CoreXYNZ build October 27, 2016 11:03PM |
Re: CoreXYNZ build October 28, 2016 06:49PM |
Re: CoreXYNZ build October 29, 2016 08:59PM |
Re: CoreXYNZ build October 30, 2016 02:23AM |
Re: CoreXYNZ build November 08, 2016 03:55PM |
Re: CoreXYNZ build November 09, 2016 04:44PM |
