Re: CoreXYNZ build November 10, 2016 10:18PM |
Re: CoreXYNZ build November 11, 2016 02:22PM |
Re: CoreXYNZ build November 18, 2016 03:05PM |
Re: CoreXYNZ build November 18, 2016 05:48PM |
zelogik
And with problem for brittle filament with direct extruder i have an idea that i can patenting!
- Just add a very small "torque" motor to push the filament with a kind of spring system to let back pressure for retractation.
No seriously I think that Stratasys or pro 3D printer have a system like that, as you put your brand new cardbridge and your filament goes until entering into the extruder.
Re: CoreXYNZ build November 20, 2016 04:32PM |
Re: CoreXYNZ build November 28, 2016 12:12AM |
Re: CoreXYNZ build December 04, 2016 12:09AM |
Re: CoreXYNZ build December 04, 2016 05:20AM |
Re: CoreXYNZ build December 04, 2016 06:51AM |
Re: CoreXYNZ build December 11, 2016 03:17PM |
Re: CoreXYNZ build December 17, 2016 06:30PM |
Re: CoreXYNZ build December 26, 2016 12:21AM |
Re: CoreXYNZ build December 27, 2016 05:39PM |
Re: CoreXYNZ build December 27, 2016 06:09PM |
Re: CoreXYNZ build December 27, 2016 07:11PM |
Re: CoreXYNZ build December 27, 2016 07:23PM |
Re: CoreXYNZ build December 27, 2016 07:30PM |
Re: CoreXYNZ build December 27, 2016 11:07PM |
Re: CoreXYNZ build December 28, 2016 01:41PM |
the_digital_dentist
Check squareness by measuring diagonals of the squares in each plane. If they match, the axes are square (for that plane).
Is the bed heated, and are you using PID control or bang-bang? Those Z artifacts could be caused by bed temperature variations.
Re: CoreXYNZ build December 29, 2016 04:37AM |
Re: CoreXYNZ build December 29, 2016 05:25AM |
filipeCampos
The z banding you have look like to have a regular undulation, is the same was the pitch of the z screws?
If yes them is probably a problem with some of the ball screw is not rotating correctly.
One suggestion that maybe solve this, you could design and print 3 pieces that secure the top of each ball screw to the main structure.
Re: CoreXYNZ build December 29, 2016 11:45AM |
filipeCampos
Re: CoreXYNZ build December 29, 2016 03:24PM |
FA-MAS
filipeCampos
I'd think you'd want to constrain the bed from moving by adding another linear rail on that side rather than constraining the lead screws. Even if you constrain the lead screws, if the screws are even slightly not straight, it would still introduce wobble to the bed. If the bed is restricted from wobbling, but the screws are allowed a little wiggle room, that would be better.
Think about adding another linear rail on the opposite side of those 2. You may also "decouple" your ball screw nuts from the bed supports by removing the screws holding them. Gravity would keep the bed in contact with ball screw nut, and since the holes they fit into are slightly oversized, it'd allow a little axial movement that shouldn't translate to the bed. Though, you'd want to make sure they're at the center of gravity for your bed.
Re: CoreXYNZ build December 29, 2016 08:30PM |
Re: CoreXYNZ build December 30, 2016 01:26PM |
Re: CoreXYNZ build December 30, 2016 03:35PM |
Re: CoreXYNZ build January 13, 2017 05:59PM |
Re: CoreXYNZ build February 08, 2017 10:59PM |
Re: CoreXYNZ build February 09, 2017 02:22PM |
Re: CoreXYNZ build February 09, 2017 02:27PM |
