Annoying z banding issue prusa i3, possible fix? February 16, 2014 12:44PM |
Re: Annoying z banding issue prusa i3, possible fix? February 16, 2014 01:05PM |
Re: Annoying z banding issue prusa i3, possible fix? February 16, 2014 02:39PM |
Re: Annoying z banding issue prusa i3, possible fix? February 16, 2014 02:56PM |
Re: Annoying z banding issue prusa i3, possible fix? February 19, 2014 07:15PM |
Re: Annoying z banding issue prusa i3, possible fix? February 19, 2014 07:42PM |
Re: Annoying z banding issue prusa i3, possible fix? February 20, 2014 01:08PM |
Re: Annoying z banding issue prusa i3, possible fix? February 21, 2014 08:58PM |
Re: Annoying z banding issue prusa i3, possible fix? February 21, 2014 10:46PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 12:04PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 12:10PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 12:47PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 12:55PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 01:10PM |
M500: stores paramters in EEPROM M501: reads parameters from EEPROM If you need to reset them after you changed them temporarily M502: reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. M503: Print settings
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 06:10PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 06:55PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 09:38PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 09:44PM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 12:55AM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 10:09AM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 10:45AM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 10:50AM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 11:35AM |
Horse Renoir
Hi all,
Heres the comparison pictures, They are both printed at 0.2mm layer heights
The one on the left is printed using Cura and the one on the right is printed using Repetier Host
[imagebin.org]
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 02:45PM |
Re: Annoying z banding issue prusa i3, possible fix? February 26, 2014 09:12AM |
Re: Annoying z banding issue prusa i3, possible fix? February 26, 2014 04:25PM |
Re: Annoying z banding issue prusa i3, possible fix? February 26, 2014 06:34PM |
Re: Annoying z banding issue prusa i3, possible fix? February 26, 2014 11:01PM |
Re: Annoying z banding issue prusa i3, possible fix? February 27, 2014 09:11AM |
Re: Annoying z banding issue prusa i3, possible fix? February 27, 2014 09:30AM |
