Errors in Mendel STL files October 22, 2009 07:23PM |
This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 587 [354] [185, 205] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 18.9600000381 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 369 [180] [139, 146] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 19.3600000381 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 596 [363] [128, 191] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 19.7600000381 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 596 [363] [128, 191] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 20.1600000381
This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 626 [341] [189, 260] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 10.45 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 767 [469] [189, 265] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 10.85 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 767 [469] [189, 265] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 11.25 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 647 [363] [63, 84] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 11.65 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 647 [363] [63, 84] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 12.05 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 106 [38] [84, 85] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 12.45 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 106 [38] [84, 85] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 12.85 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 106 [38] [84, 85] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 13.25 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 769 [469] [245, 265] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 13.65 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 769 [469] [245, 265] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 14.05 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 789 [491] [85, 260] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 14.45 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 789 [491] [85, 260] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 14.85 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 789 [491] [85, 260] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 15.25 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 789 [491] [85, 260] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 15.65
Re: Errors in Mendel STL files October 22, 2009 08:01PM |
Re: Errors in Mendel STL files October 22, 2009 08:12PM |
Re: Errors in Mendel STL files October 23, 2009 03:04PM |
Re: Errors in Mendel STL files October 23, 2009 03:42PM |
Re: Errors in Mendel STL files October 24, 2009 05:20AM |
Re: Errors in Mendel STL files October 24, 2009 04:16PM |
Re: Errors in Mendel STL files October 24, 2009 05:51PM |
Re: Errors in Mendel STL files October 24, 2009 06:59PM |
Re: Errors in Mendel STL files October 25, 2009 03:39AM |
Re: Errors in Mendel STL files October 25, 2009 04:11AM |
Re: Errors in Mendel STL files October 25, 2009 06:54AM |
Re: Errors in Mendel STL files October 25, 2009 05:11PM |
Re: Errors in Mendel STL files October 25, 2009 06:02PM |
Re: Errors in Mendel STL files October 25, 2009 06:08PM |
Re: Errors in Mendel STL files October 25, 2009 06:43PM |
Re: Errors in Mendel STL files October 25, 2009 08:51PM |
Re: Errors in Mendel STL files October 25, 2009 09:28PM |
Re: Errors in Mendel STL files November 18, 2009 06:46AM |
Re: Errors in Mendel STL files November 18, 2009 08:10AM |
Re: Errors in Mendel STL files November 18, 2009 11:39AM |
Re: Errors in Mendel STL files December 17, 2009 09:01PM |
