Errors in Mendel STL files
Posted by gerard94
October 22, 2009 07:23PM
Hello Reprappers,
I'm printing Mendel parts from STL files with a Rapman. I convert STL to gcode with Skeinforge. On two pieces, I get annoying errors from this program:
For y-bearing-180-inner_2off.stl, I get
This should never happen, there is a hole in the triangle mesh, each edge should have two faces.
587 [354] [185, 205]
Something will still be printed, but there is no guarantee that it will be the correct shape.
Once the gcode is saved, you should check over the layer with a z of:
18.9600000381
369 [180] [139, 146]
19.3600000381
596 [363] [128, 191]
19.7600000381
20.1600000381
And for y-bearing-180-outer-left_1off.stl:
626 [341] [189, 260]
10.45
767 [469] [189, 265]
10.85
11.25
647 [363] [63, 84]
11.65
647 [363] [63, 84]
12.05
106 [38] [84, 85]
12.45
106 [38] [84, 85]
12.85
106 [38] [84, 85]
13.25
769 [469] [245, 265]
13.65
14.05
789 [491] [85, 260]
14.45
789 [491] [85, 260]
14.85
789 [491] [85, 260]
15.25
789 [491] [85, 260]
15.65
In either case, the holes of the part are clogged, and there is something broken in the shape.
Do you know how I can solve this problem?
Thanks.
Gérard
Re: Errors in Mendel STL files
October 22, 2009 08:01PM
from your description, sounds like internal faces of drill holes are missing or something.. open up in AoI or blender or something and have a look, they should both have some way of finding missing faces
October 22, 2009 08:12PM
Thanks.
I'll see that tomorrow.
Gérard
October 23, 2009 03:04PM
I'm not sure which programs you have, but I know that this error comes up after modelling with Blender, when you do CSG boolean operation
October 23, 2009 03:42PM
No, I used AOI.
Well, I've still not verify this point, but I think that I understand the problem now. I wanted to rotate the object, for a correct printing without overhang. But, instead of rotating the original object, in AOI format, I loaded and used the STL files. Therefore, I think that small errors have accumulated.
I'll have some time soon to test this idea.
Thanks anyway.
Gérard
October 24, 2009 05:20AM
What I forgot to say is that when doing CSG boolean operations in Blender, it creates problems in which direction the normals go.
I've also had this error with correct normals but, some new edges created overhang, again Blender has problems with CSG, and I think they are bugs that have been fixed for Blender 2.5
October 24, 2009 04:16PM
Well, my ideas were wrong! There are really errors in the two files y-bearing-180-inner_2off and y-bearing-180-outer-left_1off in Mendel's set of RP parts. I can't convert them to gcode files without getting clogged holes and broken shapes. I used both Skeinforge and the Reprap program on the original STL files, and got similar results.
Help!
Gérard
October 24, 2009 05:51PM
y-bearing-180-outer-right_1off seems very strange too. I'm not sure, but I think there are problems inside.
bed-spring_4off gives a division by zero with Skeinforge and the result with the reprap program looks very odd.
Do you get the same problems ?
Gérard
October 24, 2009 06:59PM
I'll look at those files tonight with blender as I can check the normals and missing faces easily
October 25, 2009 03:39AM
Yep, found the problem, the problem is that there are missing faces so it can't work out how solid it is
I'll fix them
October 25, 2009 04:11AM
I've fixed them, and skeinforge reports no errors back for me.
open | download - y-bearing-180-outer-right_1off.stl (26.6 KB)
open | download - y-bearing-180-outer-left_1off.stl (26.4 KB)
October 25, 2009 06:54AM
Yes, great! It works.
Could you also have a look to these files, which have similar problems?
bed-spring_4off
Thanks.
Gérard
October 25, 2009 05:11PM
Here is the Y bearing, though the bed-spring will take some work to fix.
The y bearing had missing faces.
The bed spring is intact as a complete mesh, but it will not be printable due to the fact that it has unprintable overhangs > 45 degrees, so i'll fix that later this arvo
open | download - y-bearing-180-inner_2off.stl (21.4 KB)
October 25, 2009 06:02PM
Thank you very much. I've tried to do it myself, but didn't understand what to do.
I also can't understand why parts that look correct in AOI, and that are made by specialists, don't export correctly in STL format. Is it the exporter module that fails?
October 25, 2009 06:08PM
Bed Spring fixed.
I had to remake the mesh because of the irregularities in the mesh, plus I fixed the small errors that Blender makes with CSG modelling (non manifested vertices).
This version is now correct with the same dimensions, with no > 45 degree overhangs
Let me know of any other problems
AoI in my opinion is not being improved, or if it is, its being improved at an unbelievably slow rate, Blender is much more powerful, with features native to it that can fix problems, but Blender does have its own bugs which will be fixed, eventually
Edited 1 time(s). Last edit at 10/25/2009 06:11PM by Grogyan.
open | download - bed-spring_4off.stl (41.8 KB)
October 25, 2009 06:43PM
Thanks again.
You are certainly right, but, when I tried to learn a little of Blender, I found it much more dificult than AOI.
Do you plan to build a Mendel?
October 25, 2009 08:51PM
Blender is harder to learn, but for me it feels more natural than any other program, even against the pro packages like 3D Max and Maya. I got into Blender because it was the only program for which a complex plugin called PyPrp which essentially allows you to design a world with puzzles for the game Uru from Cyanworlds.
Blender took me around 6 months of tutorials, a couple of hours a day 2 - 3 times a week.
I'm building a RepStrap based on two old scanners because i'm a robo nut, can't be too bothered to redesign it, will do after the printer is made, i've st myself till December to get it finished, else i'll ask Vik to just print out Mendel parts for me (backup plan).
October 25, 2009 09:28PM
Wow, 6 months! I'm not surprised, but it's long. Perhaps I'll do that some day, but, for the moment, it's nice to meet someone with your skills.
And good luck for your RepStrap. Beginning with scanners is not common.
Gérard
November 18, 2009 06:46AM
Has anyone made a collection of mendel files that are already flipped, because I've found most of the bigger parts are upside down.
November 18, 2009 08:10AM
Yes, I have. I've added a new slightly wider version of z-drive-pulley-rim_4off.stl, that I've called z-drive-pulley-rim_4offN.stl.
Gérard
open | download - UprightSTL_1.tar.bz2 (279.6 KB)
open | download - UprightSTL_2.tar.bz2 (368 KB)
November 18, 2009 11:39AM
Sorry, I meant thicker, not wider.
Gérard
December 17, 2009 09:01PM
I just spent an hour trying to get one of these files to work. Could someone check the corrected files into sourceforge? I downloaded them here.
Darwin clone, Gen 2 electronics, Arduino Duemilanove w/ AtMega328, 5D Firmware, Pinchwheel extruder
[www.codeerrors.com]
