where can I purchase a 0.1 mm nozzle? January 10, 2014 06:29PM |
Re: where can I purchase a 0.1 mm nozzle? January 10, 2014 09:23PM |
Re: where can I purchase a 0.1 mm nozzle? January 11, 2014 12:29AM |
Re: where can I purchase a 0.1 mm nozzle? January 11, 2014 02:23AM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: where can I purchase a 0.1 mm nozzle? January 11, 2014 08:41AM |
Re: where can I purchase a 0.1 mm nozzle? January 11, 2014 10:00AM |
I don't know what you're trying to print but if it needs a nozzle that small FFM or FDM is probably not the right process. I also think you would have trouble getting your X and Y movement to run that accurately to utilize it. Unless you built a very specialized machine. Drilling one yourself would be a tough job at that small of a diameter those would normally be made with EDM machineQuote
bardiaesm
Im currently making a 3d printer and i need a really small nozzle(0.070 to 0.1), the smallest i can find is 0.25 which is not what i need
I cant not find them anywhere
do you guys know any place i can buy that nozzle?
Re: where can I purchase a 0.1 mm nozzle? January 13, 2014 12:15PM |
Re: where can I purchase a 0.1 mm nozzle? January 13, 2014 07:43PM |
I agree there is lot to 3-D printing it's a big learning curve it's not easy a lot of people make it sound so but it's not build your machine get a decent size nozzle somewhere around .3 to.4 and start to get a feel for it. I don't know what your machine is really like but I'm sure you are going to find many problemsQuote
aduy
you should look into milling instead. extruding plastic with that small of a nozzle size is going to be very difficult, and the calibration for the machine would simply be unrealistic. the bed would have to be perfectly flat, and the rails straight as well. if you do want to do this though start with a .4 or .5mm nozzle to learn the ins and outs of 3d printing, trust me ive used everything between 1.2 and 0.15mm nozzle and ill tell you that with the .15 the ammount of precision was terrible because the tolerances on filament basically cause a huge variation on extrusion width, also you will probably spend hours on tiny parts that will just curl up into balls.
Re: where can I purchase a 0.1 mm nozzle? January 13, 2014 07:53PM |
Re: where can I purchase a 0.1 mm nozzle? January 14, 2014 02:36AM |
Re: where can I purchase a 0.1 mm nozzle? January 10, 2016 08:34AM |
Re: where can I purchase a 0.1 mm nozzle? January 10, 2016 05:13PM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: where can I purchase a 0.1 mm nozzle? January 14, 2016 04:28AM |
Re: where can I purchase a 0.1 mm nozzle? January 14, 2016 01:19PM |
Re: where can I purchase a 0.1 mm nozzle? July 26, 2016 09:36PM |
