Cast tooling plate print bed flatness July 31, 2016 08:27PM |
Re: Cast tooling plate print bed flatness July 31, 2016 10:50PM |
Re: Cast tooling plate print bed flatness August 01, 2016 05:44AM |
Re: Cast tooling plate print bed flatness August 01, 2016 11:15AM |
Re: Cast tooling plate print bed flatness August 03, 2016 12:29AM |
Re: Cast tooling plate print bed flatness August 03, 2016 09:43AM |
Re: Cast tooling plate print bed flatness August 03, 2016 11:56AM |
Re: Cast tooling plate print bed flatness August 03, 2016 01:52PM |
Re: Cast tooling plate print bed flatness August 04, 2016 04:04PM |
PDBeal
I can understand your cast aluminum tooling plate for a machine that moved the bed in the Y plane or for a machine with a fixed bed like a delta, but I don't agree with it for a machine that would raise and lower the plate such as a CoreXY design. It would be too heavy compared to what else is out there.
Re: Cast tooling plate print bed flatness August 04, 2016 04:53PM |
unromeo21
PDBeal
I just finished my printer with the bed on the Z axis. It has a 400x400mm large aluminium tooling plate 8mm thick, cantilevered on two heavy duty aluminium shelf brackets, single lead screw 10x2, two 16mm linear rods, 4 linear bearings with aluminium blocks, everything bolted on a 245x120mm 15mm thick. Stepper is a 60Nm nema 17, no gear reduction. I haven't weighted everything yet, but that should be around 6-7 Kg. I have no problem lifting the bed, no missing steps and it has plenty of power left. I could even do "head lift" during retraction.
Re: Cast tooling plate print bed flatness August 17, 2016 08:44AM |
Re: Cast tooling plate print bed flatness August 17, 2016 10:33AM |
Re: Cast tooling plate print bed flatness August 19, 2016 11:12AM |
the_digital_dentist
Have you considered speeding up the cooling by kicking on a fan to blow on the uninsulated bed after a print has finished? That way you'd get fast heat up, better temperature regulation, and fast cool down without all the extra mass, and risk of glass breakage. I'll bet one fan is cheaper than one or a few pieces of glass, too.
Re: Cast tooling plate print bed flatness August 19, 2016 12:25PM |
Re: Cast tooling plate print bed flatness August 19, 2016 01:31PM |
n8bot
This is why I love PEI as a print surface. It doesn't lose its grip on the part while it cools down, so the parts don't warp.
Re: Cast tooling plate print bed flatness August 19, 2016 04:08PM |
Re: Cast tooling plate print bed flatness August 21, 2016 06:38PM |
Origamib
Using a fan to cool down ABS prints increases the amount of post-print warping. By this, I mean warping that will happen after the print, most likely due to the design itself. I recently had a job to print 8 large ABS mounts, which consisted of 8 legs on a circle, with 4 sprues attached to an inner circle. For about 30 minutes after printing, the pieces would start to warp as they cooled as the contraction rates of the inner circle were different to that of the outer circle. This would cause the centre to warp inwards and upwards.
As each print took around 6 hours, I used a fan on the first few to speed up the time between prints, but all this caused was further warping of the piece post-printing by as much as a few mm's. A gradual cool-down of the piece is much better.
Re: Cast tooling plate print bed flatness August 22, 2016 03:23AM |
Re: Cast tooling plate print bed flatness August 22, 2016 05:49AM |
Re: Cast tooling plate print bed flatness August 24, 2016 07:25AM |
Re: Cast tooling plate print bed flatness August 24, 2016 08:05AM |
Re: Cast tooling plate print bed flatness August 24, 2016 11:30AM |
Amoniak
For my CoreXY build (the G&C) I'm seriously considering a cast aluminum plate with PEI as my build plate with a 220v 400w silicon heater.
It just seem so superior to using what ever cheap option you use with the typical MK heatbed + glass.
The only problem I see is that I wont be able to remove the build plate as with using a glass on top of whatever heating you use.
Basically I'm worried that the Z gantry wont hold up / stay level over time from all the bending and hitting when removing prints.
I'd love to have a removable design, but I haven't come up with one that would still be robust and stable.
Re: Cast tooling plate print bed flatness August 25, 2016 07:03AM |
the_digital_dentist
I can see two possible solutions.
1) build the Z axis solid so the forces applied to remove prints won't cause any problems. Use fully supported rails or linear guides and avoid cantilevering.
2) clamp thin aluminum plates to the tooling plate bed so you can remove the print from the machine easily.
I like #1 always, and there's no reason you can't do both. A too thin plate might be flexible which could cause some problem if it bends when removing a print. In that case, use a thicker plate- maybe a second piece of tooling plate. Howard Precision Metals in Milwaukee and Minneapolis sells cut-offs for $2 per lb (recent price drop in scrap aluminum). That makes using cast tooling plate cost competitive with glass. If you don't live near Milwaukee or Minneapolis you'll probably have to pay retail which is considerably higher, or find a local supplier of cut-offs like HPM.
Re: Cast tooling plate print bed flatness August 28, 2016 06:31AM |
Re: Cast tooling plate print bed flatness November 29, 2016 01:10AM |
Re: Cast tooling plate print bed flatness November 30, 2016 01:41PM |
Re: Cast tooling plate print bed flatness November 30, 2016 01:42PM |
simspeed
I'm building an enclosed CoreXY that will use a fixed cast aluminum plate bed with a 120v silicone heater below and PEI on top. The plate dimensions are 825mm x 558mm x 6.35mm. I'm using 3 point thumb wheel leveling for the bed and I'm debating whether or not I need a 2020 frame support for the plate as shown in the picture below. The heat bed I've ordered has 3 heating zones for different sized prints. What advice can you guys give me about expansion and deflection of a plate this size when heated? Do you think the 2020 framing screwed around the perimeter is necessary? Thanks...TP
[attachment 86709 Heatbeddrawing.JPG]
Re: Cast tooling plate print bed flatness November 30, 2016 02:31PM |
simspeed
Re: Cast tooling plate print bed flatness November 30, 2016 03:50PM |
Re: Cast tooling plate print bed flatness December 01, 2016 03:09AM |
